Jean.Francois
- Joined
- May 31, 2022
- Messages
- 83
- Likes
- 314
Hello,
The Rolling Stones are back with their 24th studio album “Hackney Diamonds”, 7 years after “Blue and Lonesome”, which was a covers album, and 18 years after “A Bigger Bang”, which consisted of original songs.
For this album, 3 versions are tested: Amazon Music UltraHD in 24 bits 96kHz, Tidal MAX flac in 24 bits 96 kHz and Tidal Dolby Atmos.
The waveform of the stereo versions is without comment, with significant use of dynamics compression (DR5) as shown in the curve below:
Tidal (or Amazon) Waveform
When you zoom in, as shown in the curve below, you can see that the dynamics compression is not clean and that there are small areas of clipping (red circles):
Zoom in the Tidal Waveform
If we compare with the Atmos version downmixed in stereo (curve below), we can see that the dynamic range has been preserved (DR12):
waveform : Tidal Atmos downmised in 2.0
The Dolby Atmos mix expands the front soundstage by making the most of the side channels in terms of spatialization.
Average spatialization (Atmos 7.1.4)
When you listen to it, on the one hand you have a high-resolution stereo version (24/96) that's rather in-your-face with the dynamics compression, unlike the Dolby Atmos version, which provides much more precision and dynamics, which is noticeable when you increase the volume, the Dolby Atmos version having more impact even in stereo downmix.
You can find the extracts to compare as well as all the measurements here.
Enjoy your listening.
Jean-François
Jean-François
