Esotechnik
Russia
Esotechnik
Russia
Jimbob54
Music signal is random, not sine wave.
If your DAC (arbitrary waveform generator) cannot precisely reproduce single impulse, it cannot reproduce the stream of samples (digital music) correctly.
DSD 2.9 GHz 1bit = lossless PCM 44/16 and vice versa.
See page 9: https://www.xilinx.com/support/documentation/ip_documentation/xps_deltasigma_dac.pdf
Wise man say, if you find yourself at odds with both Pluto and Mansr on a technical aspect of D to A conversion, its a fair bet either you are wrong or possibly not putting your point across in a way that can be understood by those working in the field in question.
Pluto
Harrow, UK
Does an untruth, when repeated with sufficient frequency, suddenly become the truth or does it, like evolution, take a period of time?
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
What does 1 DSD bit produce?
pkane
North-East
Esotechnik
Russia
If their designs cannot reproduce music track or white noise in the DAC-ADC loop with accuracy after subtracting in/out 120 dB (true 20 bits in analog domain), their theories must be corrected.
80 dB correlation in old DAC+ADC only: https://www.gearslutz.com/board/showpost.php?p=14767195&postcount=2023
Why didn't any of the modern manufacturers get to the top of that rating, taking advantage of years of experience?
Esotechnik
Russia
So if you violate Shannon Nyquist
Many modern D-S ADC chips violate Shannon Nyquist due marketing "optimisation" (freq. range 2-22000 Hz +/-0.001 dB @ 44100 Hz).
CS5396 - digital filter optimized for audio (stopband min. 0.5542 fs, attenuation >117 dB)
CS5397 - non-aliasing digital filter (stopband min. 0.4979 fs, attenuation >117 dB)
PCM4222 classic filter (sharpest) - Stop band 0.5465×fs
Stop band attenuation 100 dB.
AK5574, sharp roll-off filter, Fs=48kHz:
Stopband min. 27.9 kHz (0.58125 Fs)
Stopband attenuation 85 dB
(Hello, Nyquist, from 2015!)
And this partly explains the low correlation depth (45-53 dB) in the loop test RME ADI-2 "pro" on gearslutz.
PCM4222 demo board and 1bit 64x ADC (Focusrite Blue 245, 1996 yr, 16/20 bit output) is winners in DA/AD loop overall rating (78-80 dB in/out correlation)!
Esotechnik
Russia
The last theoretically flawless audio ADC device for PCM was released in 1999:
Frequency response:
Fs 32kHz, 18 Hz-13,5 kHz:±0.1dB
Fs 44,1kHz, 18 Hz-18,8 kHz:±0.1dB - ugly for dummies! :)
Fs 48kHz, 18 Hz-20,0 kHz:±0.1dB
Fs 64kHz, 18 Hz-25,0 kHz:±0.1dB
Fs 88,2kHz, 18 Hz-35,0 kHz:±0.1dB
Fs 96kHz, 18 Hz-38,0 kHz:±0.1dB
http://www.digitalaudio.dk/media/1User_manual_2402.pdf
And no one has checked it on gearslutz yet.
AndyLu
Frequency response:
If you throw enough nonsense against a wall, maybe some of it will stick, but than you still have a dirty wall.
Esotechnik
Russia
Well, show an example of lossless conversion PCM 44/16 to DSD and back, if you are so smart. Without 2.9 GHz bitstream.
And none of the deaf delta-sigma converters fans have achieved 16 bit (96 dB) of digital precision in the analog loop on a music track.
On "24-bit" or 1-bit "hi-res" systems ;)
