Topping D10s USB DAC and Bridge Review
staticV3
Yep. Schiit Urd unison usb output. It’s very picky about what it plays with despite Schiit claiming anything UAC compliant works.
You can simply convert the Urd's Coax output to Toslink, with one of these inexpensive converters:
Or is it that you need both Coax and Toslink out of the Urd?
staticV3
Thanks but can imagine it wouldn’t work with those either. I know the Topping D10 works so I’ll go with that.
It would 100% work. And at a much lower cost than the D10s, and with identical sound quality.
staticV3
That contraption still needs its own power source. No good to me.
If it must be USB powered, I would first try the Hifime UT23.
It's way less expensive than the D10s (no built-in DAC, go figure), and extremely basic (UAC1, low power consumption), making it highly compatible.
Mantra
Central Europe
hi
but about these cheap dacs , about the drivers ?
should I use V5.57 & V4.86 driver for most of TOPPING DACs ?
thanks
Mantra
Central Europe
Yes, all the drivers work the same. I didn't even update mine for years.
hi
no problem with usb power supply ,right?
for the usb power supply i mean noise
thanks Jimster480
Jimster480
Tampa Bay
hi
thanks Jimster480
Honestly, just use a good USB adapter, like a first party Samsung charger or LG or HTC, as all of those are quality. Otherwise, just buy one quality charger.
Aldoszx
I suppose we are talking about D10s here, is that right?
In this case, you don't have to use a power supply !
D10s is powered directly from USB port. There is not a separate power input socket.
Toku
Japan
Yes, it's supposed to be D10s, but the topic seems to be moving in a different direction.
