- Joined
- Oct 1, 2018
- Messages
- 826
- Likes
- 1,226
D70...
Does the issue still exist after you change other players? Or pls try to change USB-port, USB cable.D70...
does anybody have an issue with their d70 where occasionally, while opening and closing programs (happens when I close mpc media player usually after fininshing a video or movie) something will mess up, windows 10 wont recognize the dac anymore and you'll need to turn the dac off and on to reset?
How do you like the UX? Are controls responsive etc.?Here you go
Do u mean the filters? If so there's a description in the manual. It's a personal preference thing, although most can't hear an audible difference between any of them.Its responsive. No problems with that. Sound is excellent for my ear. I have not had enough time to play with it yet to talk fully about it.
It looks good. Feels like good quality. It's heavy.
I love that you can set it to turn off the display after 30 seconds.
Also thanks to SHENZHENAUDIO for fast delivery
The manual could have been much better. A good manual would have answered the thing I wonder about below.
It could have had one buttons named options/settings with access to settings on the device. Maybe there is one with a dual function (not looked for it yet (used the remote so far). I have not figured out how to disable bluetooth yet. Or if it's disabled by default. But again not had enough time to look for it
Also the remote could have had buttons with names.
When choosing modes the device could have told me that Mode 3 was default. It just says Mode 1 - 6 (the manual said 3 was default). Maybe had a name after. F example Mode 1 Name, Mode 2 Name, Mode 3 Default, Mode 4 Name, Mode 5 Name, Mode 6 Name.
Thanks for your feedback, as well.Its responsive. No problems with that. Sound is excellent for my ear. I have not had enough time to play with it yet to talk fully about it.
Look at price for your answer.What is best X16 or SMSL su-9 or topping D70s ?..
Price?.? Must be a thecnical comparisationLook at price for your answer.
They are audibly all the same and measure the same, but one is cheapestPrice?.? Must be a thecnical comparisation
Hi there, has anyone had issues with this dac and MQA streams?
The issue I’m having is that the dac does not seem to lock onto the MQA stream properly, resulting in the following:
Any thoughts?
- Pressing play can result in the playback slider advancing, but no sound
- advancing or rewinding the playback slider stops sound, while slider continues to advance from placed position
- Left or Right channels will sometimes not work (playback from one channel only)
- Pausing and restarting will result in no sound, while playback slider advances
- track advance or rewind will often result in no sound but playback slider advancing.
I am only having issues with MQA streams. Regular FLAC/AIFF in CD and 24/192 quality and upsampling to DSD 512 (as as test) through Roon show no problems.
I have been in touch with Topping service and they have confirmed issues with MQA files from Mac OSX Tidal app -> USB into the D70s - pause and replay result in long times to resynch to the stream (they find it to be 4 seconds, on mine it was longer to indefinite - sometimes it never played as the counter advanced). They seem to be a big more sanguine and ok about their experienced 4 second gap than I am but that may be my interpretation of the email.
I've tried RopieeeXL and VitOS with a wired Pi4 going usb into the dac - basically the setup does not work for MQA files. Apparently RopieeeXL logs show RoonBridge reporting buffer underrun errors and USB input/output errors. It results in the 5 points from my post above.
Works great as a non- MQA dac though
