- Joined
- Oct 11, 2019
- Messages
- 1,867
- Likes
- 2,806
Well, I was counting the total number of IC’s—31 not counting the DAC chips. Doesn’t seem very discrete to me!Hmm. I see 4 opamps for i/v, 2 for SE out, 2 for Vref.
Can you give some specifics? Like a list of DAC's tested? Was the problem only affecting the SU-9 and the M500? Did you happen to also test the Gustard X16? Your site gives a short "preview". I'm not sure if a final review was done.Absolutely no such issue,After the M500 incident, I used the same conditions to measure more than 20 DACs, including the D90se.
The last frontier is the "battle for the transducer" The loudspeaker (and headphones) companies have a long R&D road ahead of them to match the level of optimization made in the rest of the chain.OK now that the audio DAC is a solved problem w.r.t measurements (I guess it has been solved for a while w.r.t audibility), I'd say almost the same for the amplifiers.
Please dear R&D departments of all audio companies turn your resources to the weakest part of the audio chain (and stop trying to break all ready broken barriers). Speakers!
We need to see this affordable, technically outstanding performance (good and/or constant directivity, low distortion, high spl) for speakers (instead of th hiese 10k$+ product mostly targeted to the almost niche audiophile and just wealthy but not so audiophile crowd).
funny, I saw in the publicity of the product to advertise its preamp capabilties with some Genelecs. That's definitively a great jump upwards.
@Amir,
could you test the bluetooth?. More a more products have it. How BT progresses compared to USB?.
I totally second the last part of your comment. The techniques from kii, d&d, genelec, etc... needs to be used in products that should have sell count numbers maybe one order of magnitude higher to smooth out the big R&D cost + the cost related to small volume production.The last frontier is the "battle for the transducer" The loudspeaker (and headphones) companies have a long R&D road ahead of them to match the level of optimization made in the rest of the chain.
The countries that have invested more in audio research have comparative
advantages: CA, DK... So do those with a long tradition of audio research, both in academia and in successful startups. A lot of the tech is already there, but it needs to trickle down from ubercostly studio monitors to the listening room. Economies of scale need to kick in.
It looks quite nice but I am not convinced if I got it if I could tell the difference over my current Topping D30.
That would be a hypothetical "DX90", a (Streamer?)/DAC/PRE/HPamp combo: a machine set to seek first place in this category of products. In the meantime the new dac is a neat stack fit with the A90 hp ampWow.
@JohnYang1997 when it this DAC performance going to add powerful headphone output/s inside same box ?
A few people on this forum (audiophiles apparently) had the SMSL SU-9 with a true SINAD < 80dB and have never noticed anything.
Switching power supplies tend to be free of mains noise and as Benchmark as shown, can be the key to highest performance audio products. They are also universal as far as input voltage. I can't tell you how many products I have received from China that were set to 240 volts and would not power up until I discovered the switch underneath.Perhaps because of cost reduction?
Same. While we can certainly admire the quality of the implementation, I don't think there is any value in chasing SINAD for the end-user.
Let's face it: most Hi-Res music is essentially a ripoff.
Interesting, thanks!Switching power supplies tend to be free of mains noise and as Benchmark as shown, can be the key to highest performance audio products. They are also universal as far as input voltage. I can't tell you how many products I have received from China that were set to 240 volts and would not power up until I discovered the switch underneath.
This ^^^^^^ a 100%. Topping should look at the Parasound Halo Pre's and do some tweaking with that design and feature set.D30 Pro is lacking BT btw. At this point, assuming the DAC meets audibility threshold, it's become about features, support, price, etc. For this price I'd rather see SW out (and a way to implement the crossover to the main speakers) and some PEQ than more zeroes in THD+N. Nonetheless very nice achievement!
Interesting, my HiFi buddy believes the same that discrete components hand chosen will have superior quality over the op-amps
While we're on the subject of power amplifiers, let's shoot for the moon: at least 300 watts into 8 ohms and stable down to 2 ohms plus bridging capability for dual mono applications - and the standard to beat is the Benchmark AHB2 at one third the price.for the love of god, poweramp to complete this fairytale.
true SINAD? Is that like a true scotsman? Amir showed it at ~120.
Actually, companies like iLoud is on the right track following in the footsteps of Genelec, Dutch & Dutch, etc. so the recipe is fairly straightforward: waveguide + DSP = best sound. Genelec took it up a notch by making it coaxial and letting DSP fix the shortcomings of the coax but now you have amazing vertical directivity. The hardest and most expensive part is DSP programming - maybe Dirac or Anthem will license their technology for implementation by speaker companies?The last frontier is the "battle for the transducer" The loudspeaker (and headphones) companies have a long R&D road ahead of them to match the level of optimization made in the rest of the chain.
The countries that have invested more in audio research may have comparative
advantages. So do those with a long tradition of audio research, both in academia and in successful startups. A lot of the tech is already there, but it needs to trickle down from ubercostly studio monitors to the listening room. Economies of scale need to kick in.
That's all I needed to hearWon't say I won't.
If it were "just" upsampled music, which you can easily recognise with a sound editor because all frequencies are under a certain frequency and everything else above is absent. But you can even find something like this:
This is a horrible example from a commercial 96/24bit download. There is actually no content above 24Khz, what you see is a very strong image of the original signal below the 48khz frequency (the nyquist frequency corresponding to a 96khz sampling rate), I wonder how this can happen. The sound must have been played through a very bad NOS DAC and then re-recorded. Perhaps to do mixing in the analog domain? This is just a hypothesis, and quite an unlikely one, to be honest, but overall I cannot see how they could generate such a monster. Any idea?
Fact it, it does sound better just decimated down to a 48K sampling rate... and it occupies less disc space!
