Topping DX7 Pro+ Review (DAC & HP Amp)
Rate this DAC & HP Amp
    Votes: 8 2.2%
    Votes: 10 2.7%
  • 3. Fine (happy panther
    Votes: 56 15.4%
    Votes: 290 79.7%
aaddas
Saudi Arabia
TOPPING DX7PRO+ VS D30PRO
Who is win?
Roen
Is there anything that this cannot do that the D90SE/LE can do?
Snoopy
The DX7Pro+ cannot output 5.2V like the D90LE. It's limited to 4.2V
I'm wondering how a combo unit like the dx7pro handles native DSD since they use a digital volume control.. normally this should result in noise .
Roen
Has to be used at full volume.
Roen
With the lack of an analog volume control and 4.2 V vs 5.2 V, looks like I’m going D90LE or SE at a good price.
Snoopy
Both have a digital volume control.
Why not just get the Topping E70 or E70V ?!
Roen
Both will require an amp for DSD, and if so, I'd rather take the 5V mode of the D90 SE for a few hundred more.
Clancy1994
Looking to purchase this or the FiiO K9 Pro, to drive HD800S, any idea which would be better? mainly used for gaming and music with a touch of TV
Mordred
I have a weird problem with the dx7 pro+
For some reason it is stuck in pre out mode. In the settings i selected DAC mode and Lineout XLR also factory resetted the device. This is a bad situation cause i have headphones and active monitor speakers. every time i want to use headphones i have to turn the volume down or the otherway around when using the speakers again.
anyone an idea how to fix this mess?
staticV3
@Mordred so you go into the Setup Menu, select LO Mode | DAC, then you select Save and exit, and still the next time you go into the Setup menu, LO Mode has reset to Pre?
Mordred
No it says dac but it is still not fixed and gets controlled together with the headphone just like in premode
staticV3
Could you try setting Output to PO?
On other Topping AIOs, even with LO mode set to DAC, the Line out stays adjustable until you disable the headphone out.
I can't find anything of that sort in the manual, but maybe the DX7Pro+ behaves the same.
nsfgp
Read the manual again carefully. The default for Line Out mode is in PRE-AMP mode. You have to enter the setup manual to change it (remote won't work).
Entering the setup menu may require unplugging the power cord, hold volume knob while plugging in power cord (like how it works on DX3Pro+).
I am pretty sure it is not an issue with the unit. Learn to control it. Good luck. The way Topping design the output combo is one of the best I have seen. It is the same from DX3Pro+ to DX5 to your DX7pro. EDIT: You have an extra power switch at the back so likely no need to unplug power cord. FYI. Just hold volume knob while flipping the switch at the back and see if it enters setup menu.
staticV3
@nsfgp
Mordred knows how to enter the Setup Menu.
It's just that the way the DX7Pro+ works, does not work for him.
