Pdxwayne
- Joined
- Sep 15, 2020
- Messages
- 3,219
- Likes
- 1,172
Edit:Check with your speakers and see if you hear them the opposite way than your headphones or with the Gustard. If what was once original now sounds like inverted, that might mean the phase is.inverted on the RCA output. If it sounds the same as with the gustard, then phase is not the culprit
Just now, I was using my phone to do the test to see if I can pass test. Next will be with e30 and headphones. Then, if no issue, will be with speakers. Thanks!
