Topping E30 DAC Review
solderdude
The Neitherlands
Hmm, what do you say about this comparison?
DAC volume matched at 2khz
Same song, same first bass beat. Zoomed way in to select start of first beat to the start of next beat. Same amount of time selected to create frequency analysis.
It would seems they don't behave the same in multiple area in term of energy level for many frequencies. ~440 HZ is one area of interest. Top of each picture is Gustard. Bottom of each picture is Topping.
Or is this all for naught again? Bad ADC that caused the differences?
When you are venturing in this type of measurements perhaps it is time not to wing it using UCA202 but to buy something more decent/reliable.
You are measuring micrometers with an ordinary ruler.
Try @pkane his nulling software. That is way more suited for these kinds of tests AND lets you listen to the differences as well. You can even post that and have some objective evidence.
Pdxwayne
Can you share the files? You might also try some
White noise.
How many seconds can I legally share for a song? Thanks!
Edit: I will repeat the recording process for same song a few times first. Don't want to waste people's time if indeed my uca202 is the problem.
Pdxwayne
Thanks! Yeah, my worry is the UCA202. I will try record same song a few times for one dac and see if it is consistent or not.
Pdxwayne
@voodooless and @solderdude, I figured out why such big different. Human error. :facepalm:
I was measuring left channel of x16 and compared to right channel of E30.
Once I switched to left channel of E30, the chart look the same and have similar dB at multiple frequencies I checked. :). So for a single bass hit section, both DAC performed the same.
I then moved on to compare a section of the bagpipes song. Both DAC matched volume as before.
However, strangely, in this case E30 is slightly louder at all freq. Starting from about 0.2 dB louder at bass level to 0.5db louder at around 10 to 11khz area.
I am going to further investigate.
half_dog
Brazil
Yup. Just finished a 2Khz sawtooth measurements. Gustard x16 (left) and Topping E30 (right) look the same with 2Khz sawtooth playback.
Today I "discovered" REW beta version has a scope option and seems quite okay to check somethings like absolute polarity at real time, also to check how FIR influences overshooting on square or sawtooth waves and ringing. A high sample rate is desired to get a good resolution.
JohnYang1997
China
When I read the last sentence..What?
solderdude
The Neitherlands
That didn't even cross my mind. Funny how one assumes that when one compares music one would always compare the same channel.
half_dog
Brazil
Oh, sorry. Sometimes I can't explain things very well or probably I'm wrong. At REW you can select the audio interface sample rate you wish to work with. Higher sample rates do mean more points for a time interval, no? Am I saying something stupid? Pls correct me. That's what I understand...
solderdude
The Neitherlands
The scope is in there for quite some time and indeed only works in live mode.
You can't look at waveforms that have been captured.
I never use it (have a real scope that doesn't 'ring')
To check the phase one can also simply look at the phase in the FR plot (you can toggle it off and on)
JohnYang1997
China
Alright. I understand now.
half_dog
Brazil
At the first measurements my interface was working with 44.1kHz and the ringings was exaggerated and a little of zooming REW would display the sample dots(I don't know the right term) , with 192kHz I was able to zoom much more and the waves seemed smoother...
half_dog
Brazil
I already knew about the phase on FR but never have seen the scope option - never used a beta version before =P
solderdude
The Neitherlands
It is there since at least 2013.
Pdxwayne
I did lots of measurements today.
I first check the consistency and accuracy of my UCA202 single channel measurements.
With E30 volume set at -8.5db, using filter 1, I measured 2Khz and 10Khz tone 3 times each. I confirmed I got matching db numbers for all 3 captures per freq.
E30 (-8.5db, filter 1, 2Khz tone generated at 0.8 out of 1 in Audacity): 0.9db
E30 (-8.5db, filter 1, 10Khz tone generated at 0.8 out of 1 in Audacity):0.8db
There is a drop of 0.1db between 2Khz and 10Khz.
I then checked E30 measurements by Johnyoung89 from Topping. Indeed there is a slight drop in dB for filter 1 in 10Khz. Not exactly 0.1 db, but Audacity can only show 0.1db increment.
Now that I established my UCA202 can accurately and consistently do single tone measurements, I checked Gustard x16 measurements next.
I have previously established that E30 has higher output than X16, thus I measured x16 at -8db, using same test files.
Gustard X16, -8db, filter 1:
2KHz: 0.7db, 10Khz 0.4db
Gustard X16, -8db, filter 2:
2KHz: 0.6db, 10Khz 0.4db
Gustard X16, -8db, filter 3:
So, it looks like X16 drop from 2Khz to 10Khz is either 0.2 or 0.3db.
E30 has a drop of 0.1db with filter 1 at around 10Khz.
Gustard X16 (I was using filter 3) has a drop of 0.3 db at around 10Khz.
The question is: Can one sense such small difference of 0.2db between DAC at 10Khz? How about more and more db differences at freq higher than 10Khz?
AnalogSteph
.de
The limit of discernibility is about 0.3 dB, and above 10 kHz things should get less and less critical are hearing sensitivity plummets. So I'd say nothing of that should be audible.
Pdxwayne
I only checked up to 11khz and the difference at 11khz is ~0.3db between DAC (when volume matched).
But I think my uca202 and audacity might have reached it's limit of accuracy....So I am going to stop for now knowing that there indeed could be differences in the highs.
solderdude
The Neitherlands
Have you checked how high your hearing goes ?
Use the E30 on a sharp filter setting. Don't set freq. above 20kHz you might be hearing aliasing and think you can hear 21kHz.
Set the volume at around 400Hz and then sweep downwards (NOT upwards) from 20kHz.
There is plenty of online generators. Don't cheat by upping the volume at higher frequencies.
Use a headphone that is known to reach 20kHz (say HD600/HD650).
Then, ask yourself how important the differences above say 15kHz could possibly matter.
Pdxwayne
My measurements were showing differences between DAC for 10khz (~0.2db) and 11khz (~0.3db). I am wondering if those are the freq that give the E30 extra "sparkles". Or it is from even higher freq?
I don't have good headphones. The current ones on hand cost $99 the most. On the other hand, my stereo amp claim to have freq response up to 100khz. My speakers also claim over 40khz freq response.
However, as you can see, my speakers pretty much emphasize 7 to 10 kHz:
I will use REW to test my speakers setup like you suggested when possible. Unfortunately, my family members are at home all the time......
The YouTube tests with headphones I did a while back showing that I am only good up to around 15 to 16khz anyway....
solderdude
The Neitherlands
0.1dB difference is inaudible, even when it is switched AB.
The extra sparkle requires quite a few dB.
The measured speaker (under test circumstances which is not your home) seem to have the BBC dip.
1 sub division is 1dB imagine how 0.1dB would register on that same scale. You cannot even see it as the thickness of the trace in the plot is already bigger.
