Topping E30 DAC Review
half_dog
Brazil
I would suggest to use a online tone generator or REW signal generator (you can setup it to play a specific tone) because YouTube encode their videos and audio to a lower "quality". Maybe you can hear above 16kHz and YouTube is limiting high frequency content.
solderdude
The Neitherlands
The tone generator I linked to can indeed reach 22kHz.
The danger of using even higher frequencies (when using speakers) is that one may be accidentally turning up the volume control in order to 'hear' high frequencies and burn your tweeter in the process because you don't hear it. Be careful with speakers. Adjust volume at 400Hz to 1kHz or so in a way that it does not sound loud and then don't touch the volume control.
Only sweep from high to low because the other direction (from low to high) may be deceiving. You may believe you still hear something when it is already gone.
The REW tone generator is fine too of course. The same applies. Be careful using speakers and loud high frequencies. Never try to find out when you can hear 16kHz again when it stops at 15kHz. Tweeters are low power rated in general and don't like continuous tones.
Pdxwayne
Did some tests today.
Gustard X16 with all 3 filters set at -20db.
REW tones also set at -20db.
Listening ~10 ft away from speakers.
At that volume, 400hz and 1Khz are clearly heard from listening position. Unfortunately, the highest I can sense is ~13,800hz from 10 ft away at same volume. My daughter upstairs in her room complaining about the tones I can barely hear. : (
My room is heavily carpeted. Still, definitely my high frequency hearing deteriorated a lot already..... but maybe still pretty normal for my age.
Will check E30 later when have the opportunity.
Pdxwayne
My daughter couldn't stand high freq with stereo setup, so I could only do short tests and it seems my limit with E30 with my stereo setup (e30 -20.5db and REW at -20db, sitting at ~10ft away) is similar to x16, at less than 14khz.
I just checked with my $99 headphones with REW (USB to DAC, DAC to L30). Using a decently loud level at 400 Hz, I could sense up to ~16khz. 14khz definitely easy to sense. Using this headphones information, I would guess when I go decently loud with my stereo setup, I could sense up to around 16khz or so with my speakers....
companyja
Somewhat silly question perhaps but I'm just trying to figure out where I'm going to put the DAC once it arrives - does anyone know how long the USB power and signal cables are that come with the E30? I need a bit less than 1m for both. I imagine the USB signal cable might be 1m since that is the standard but I'm worried that the power cable is shorter and I'll need to do some dumb things with extensions to get it to where it needs to go.
I'm struggling to find the answers, perhaps I'm bad at looking but haven't found the info anywhere yet
Robin L
1 mile east of Sleater Kinney Rd
The provided connector/interconnect for the E30's power is about a meter long. It uses standard USB to a charger on one end. The other end [that connects to the E30] isn't the standard connector, but it's not so exotic than you couldn't find a longer interconnect if needed. Conversely, a regular AC extension cord would also work. I stack the E30 and the L30, so I got myself the shortest connector of decent quality I could find, about a foot long. As the output connects to RCA jacks, should be no problem finding something around the house that works.
companyja
The provided connector/interconnect for the E30's power is about a meter long. It uses standard USB to a charger on one end. The other end [that connects to the E30] isn't the standard connector, but it's not so exotic than you couldn't find a longer interconnect if needed. Conversely, a regular extension cord would also work. I stack the E30 and the L30, so I got myself the shortest connector of decent quality I could find, about a foot long. As the output connects to RCA jacks, should be no problem finding something around the house that works.
Ah, so even the power cable is at least a meter? That's good news since I was fearing it was shorter. If it's a meter, it should reach either my PC or a power plug. Thanks for the info!
Robin L
I got a 3 meter interconnect to link my computer [a laptop] to the E30. Set me back something like $8.
companyja
No problem with the singal cable length (USB-B in the DAC > USB-A in the PC). I was wondering about the USB power cable (barrel-type adapter in the DAC > USB port on charger/PC). Sometimes manufacturers give a really short one of those. If that one is also about 1m, I should be able to fit everything with the stock cables. I have lots of those generic USB signal cables, but I don't have a USB to barrel power cable nearby.
yodog
I did lots of measurements today.
I first check the consistency and accuracy of my UCA202 single channel measurements.
With E30 volume set at -8.5db, using filter 1, I measured 2Khz and 10Khz tone 3 times each. I confirmed I got matching db numbers for all 3 captures per freq.
E30 (-8.5db, filter 1, 2Khz tone generated at 0.8 out of 1 in Audacity): 0.9db
E30 (-8.5db, filter 1, 10Khz tone generated at 0.8 out of 1 in Audacity):0.8db
There is a drop of 0.1db between 2Khz and 10Khz.
I then checked E30 measurements by Johnyoung89 from Topping. Indeed there is a slight drop in dB for filter 1 in 10Khz. Not exactly 0.1 db, but Audacity can only show 0.1db increment.
Now that I established my UCA202 can accurately and consistently do single tone measurements, I checked Gustard x16 measurements next.
I have previously established that E30 has higher output than X16, thus I measured x16 at -8db, using same test files.
Gustard X16, -8db, filter 1:
2KHz: 0.7db, 10Khz 0.4db
Gustard X16, -8db, filter 2:
2KHz: 0.6db, 10Khz 0.4db
Gustard X16, -8db, filter 3:
So, it looks like X16 drop from 2Khz to 10Khz is either 0.2 or 0.3db.
E30 has a drop of 0.1db with filter 1 at around 10Khz.
Gustard X16 (I was using filter 3) has a drop of 0.3 db at around 10Khz.
The question is: Can one sense such small difference of 0.2db between DAC at 10Khz? How about more and more db differences at freq higher than 10Khz?
Can you measure toppings filter #5? I use this filter often and curious how it compares
yodog
Guys, I was wondering something. I noticed my topping e30’s left and right rca connectors are backwards compared to my bluesound node 2i.
I was wondering if topping e30 is backwards or if the bluesound node 2i is?
Does anyone know if topping intended for the user to interpret the “left” and “right” RCA’s when looking at the DAC with the screen facing you or from behind ? Which way is the correct left and right for the e30 DAC?
Pdxwayne
Looking from the front, both my Node2i and Topping E30 right RCA is on the right.
Overseas
I use the E30 with my amp+speakers system, Tidal streaming via phone OTG cable.
What exactly can this app do for me:
https://www.extreamsd.com/index.php/products/usb-audio-player-pro
When connecting an Android phone or tablet to a USB DAC, USB Audio Player PRO will unleash the full power of the DAC, by using our custom developed USB audio driver. This bypasses the Android audio system completely, meaning that Android's limitations regarding bit resolution and sample rate (16-bit/48kHz) are made irrelevant and high quality audio streams are fed directly to the DAC, making playback up to 32-bit at 384kHz possible (depending on the DAC capabilities) or even DSD.
I gave it a try with the trial version and felt nothing except cutting bass a little and having to deal with a new interface.
Thalis
It gives you the option of bitperfect transmission and PEQ.
dgnzcn
Turkey
Hello, can you tell me what is latest serial number starting first four number for E30 and all issues are resolved in latest version?
companyja
2009 and onwards are identical I believe. I think 2004 onwards is safe too but I remember hearing 2009 was different in some way. If you get a new E30 which is older than September of last year that would be kinda incredible
Pulkass
I recently contacted Topping about an issue where an audible pop occurs when using the USB input and coming out of standby. This pop only occurs coming out of standby and no other time. If the DAC is already on and displaying the flashing blue USB symbol and I turn on the player then the display shows the same (45.15 DSD changing to 44.1 PCM) but no pop. I sent Topping a video showing the issue and their final reply suggested the DAC maybe faulty and to return it. I have seen other posts mentioning a pop at start up so I don't want to return it if they all do it. I have attached a link to my video of the issue. Does anyone have an E30 that does not have an audible pop when coming out of standby using the USB input?
Video of audible pop
I cannot use the E 30 in USB mode, too much noise, it seems mains noise but it aint, The Cambridge audio, same mode is absolutely silent, and this problem occurs at a friends too, same setup. No pops, but a never stopping grinding noise.
