Topping E30 DAC Review
Atanasi
So I understand that android (7.1) in tv box Himedia Q5pro and android 12 in samsung actually resampling to 192 kHz and it is not a display error topping e30?
It is possible. Samsung actually has a selectable upsampling mode (UHQ upscaler) that upsamples to 192 kHz and maybe does something else too.
nsfgp
Hello.
My topping e30 surprised me with the sampling rate of 192 PCM (kHz) under android as source. I was expecting android to resamble everything to 48kHz, and here is such a surprise. This is true both for the TV Box with Android and for the Samsung Note10 smart device. From the Neutron application with "direct usb access" enabled, it shows the correct sampling rate. Is it so in this model or maybe it is some kind of fault.
Try Hiby player ... you have full control how it resamples or not; native DSD, hardware volume control, etc. Works great with E30 and S9.
Dac Visitor
Amsterdam NL
The Interlinks have arrived and are playing. As if an invisible curtain has opened. More definition, more control, much more refinement and air. All that remains is music in its purest form. Fantastic.
kolestonin
I use the two RCA outputs of my Topping E30 to connect my current sub woofer.
What are my wired options in case I want to add a second sub woofer?
Can I hook them up as stereo subs, one channel to each sub?
In this case what will be the drowback in respect of connecting the 2 subs to a DAC with 4 RCA outputs?
misfits73
London
In order to play iso SACDs or dsf files with foobar,which method do you follow to set it up properly?The one included in the Topping's driver file or the components available at the foobar's page?
Nelaer
Poland
The one included in the Topping's driver file works properly
Pulkass
It s impossible. A friend of mine did it via access to my puter, very complicated, Foobar is almost impossible to set for DSD files. I have bought another dac do 100. Because l needed a fully differential balanced dac, but the problem remains, no software, no help from Foobar, no video. No nothing
staticV3
Playing DSD in foobar (both DoP and Native) is really not that hard:
staticV3
Yes thanks, but there are many tricky passages before that, preferences or something called like that. It s not that simple at all
The steps I sent are literally all there is to it. There are no additional preferences or something.
This friend of mine set it once. But l listen to Tidal, Spotify, my normal files FLAC, mp3 in my puter, after that l could not listen to normal audio. Dsd is occasional.
When set up like in the screenshot, I can listen to MP3s, WAVs, FLACs, DSFs, whatever, without changing settings. And they're all played bit-perfect.
Pulkass
Ok thanks l will try.
andrewskaterrr
STL
When I set it up, I had to download the DSD support plugin, then add it to Foobar2000. Then I think I had to add it as an output option.
Labjr
Foobar2000 isn't bad once you get it going. However, I've always found it to be a royal PITA to set up. Like entire days of pulling my hair out!
misfits73
London
Thanks for your replies, i use it basically as i rip my Cds to flac with cue sheets and i find foobar quite easy to open the cue files.
Jriver was so complicated for me, havent tried any other player though
geopapa
Make sure your volume is set to 100% when playing DSD. if it is anything else than that it doesn't work
fritobugger
Hanoi, Vietnam
Foobar is playing DSF files without issue through the E30. 64, 128, and 256 without any problems.
nsfgp
Using USB on a PC to E30 this is the way I set it up and the easiest with the minimum plugins and config you needed to get/do. Works great for playing Native up to DSD512 which should cover all your needs. (If you really need DSD1024 then you can config/use the DSD Processor plugin to convert it to DSD512 or lower to play). Do not follow/use the stuff included w/ Topping driver (outdated old stuff).
0. Install latest Topping/SMSL/etc. ASIO/XMOS driver for your particular DAC.
1. Get 2 plugin and install: foo_input_sacd(foo_input_sacd.fb2k-component), foo_out_asio+dsd(foo_out_asio+dsd.fb2k-component) from https://sourceforge.net/projects/sacddecoder/files/
2. Select the "ASIO+DSD: Topping USB Audio Device" as Output Device (select your device if not topping brand).
3. In Tools/SACD tab: Select either DSD or DSD+PCM as Output(Per Device) type at the top. Both works the same in native DSD (w/ only difference you can see the visualization stuff working if you select DSD+PCM). No need to select/config DSD Processor (unless you need to play DSD1024 or anything above your DAC's limit).
That is all you need. No need to config any conversion/transcoding as you want Native DSD only (no DoP or PCM conversion) for the best compatibility.
4. To confirm it is indeed playing in DSD mode and the intended sampling rates open the Topping Driver control panel and confirm w/ the ASIO Status screen while playing.
(included some screen shots below)
Pulkass
0. Install latest Topping ASIO driver.
2. Select the "ASIO+DSD: Topping USB Audio Device" as Output Device.
3. In Tools/SACD tab: Select either DSD or DSD+PCM as Output(Per Device) type at the top. Both works the same in native DSD (w/ only difference you can see the visualization stuff working if you select DSD+PCM). No need to select/config DSD Processor (unless you need to play DSD1024).
Thanks, I have a SMSL do 100 dac, no asio driver available, Tools is a blank page in Foobar !!!!! I have installed
