staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,013
- Likes
- 12,855
No.Is this extra 0.2V a concern?
Big? How is that possible?I was using two E30s, but after purchasing an additional E30ll, I was surprised at the difference in sound quality between the two.
The evolution from E30 to E30 ll is big.
It seems that my English expression was not accurate.Big? How is that possible?
It was clear Toku I think @Rottmannash is just sceptical, big change! Really.I just wanted to say that you can actually feel a clear difference in sound when comparing the E30 and E30 ll.
1) doesn't really matter. you can leave it offHi all, I have 3 questions for you
windows 10 LTSB in use
1) when installing the drivers, the Topping E30 II must remain off, or on what is the procedure to follow ?
and if I have to install a new driver do I have to delete the old one? , or I'll rewrite it above
2) once in DAC ONLY MODE, how do you go back to PREamplifier status?
3) must he be burn in ?
Thank you
Accoridng to the E30 II manual:@Veri hi, forgive me but in the manual, I only read how to set it up as a DAC , but not how to return to PRE mode
can't I see it?
It is a possible option, but I would adjust it in the amplifier to which the DAC is connected, so as not to alter the digital signal.if I use topping as a smooth DAC, the Volume ? is adjusted by the PC Music Player ?
Did you use this fast charger along with smartphones or other stuff? Which brand was It? Maybe It was not reverting to 5V when disconnected.I used a fast charger with my Sony Pha-2a dac/amp and now the unit is unusable anymore. Cannot be charged. Usually when charging one should see a blinking red light but now it is a blinking amber light and when I switched on the unit, there is no more power (no green light). Avoid fast chargers
It's a no brand charger but there is a "budi" that's written on it. I don't think I was using it before charging the dac/amp and it was such a good dac/ampDid you use this fast charger along with smartphones or other stuff? Which brand was It? Maybe It was not reverting to 5V when disconnected.
...I might be sending mine back, eh...I haven't actually tried to do anything with it yet...Accoridng to the E30 II manual:
First, enter the setup mode: In the standby state, press and hold the multi-function touch button on the front panel for 5 seconds to enter the setup menu.
Second, with the remote control, press the volume up/down button to get to the output mode setting which will display the value “m-d” as the device is in DAC mode (fixed max output value). Then, press the left/right button to ser this parameter to the m-p” preamp volume adjustable value.
Third, press the OK button and the E30 II displays “8-8” indicating that the settings have been saved.
