Topping PA5 measurements )
daniboun
France (Lyon)
Hi amigos,
The new Topping PA5 is here, checkout :
Pdxwayne
Hi amigos,
He estimated $399 price. Should be great for my computer room setup.
pozz
Слава Україні
Editor
Excellent.
Lead the way, China.
Matias
São Paulo, Brazil
Most impressive.
abdo123
Brussels, Belgium
50W @ 8 Ohm?
I will skip this one. Not interested in a garage amplifier for 400$.
Edit: the reduced price pushed me towards being a big fan of this product. I retracted all the negative statements i have made in this post and the following ones.
Zek
There is no graph of the total / maximum power of the amplifier in relation to the distortion so you can conclude that.
That last graph measured at 50W / 8ohm does not mean that it is the maximum power of the amplifier.
Trokox
Hi amigos,
Awesome. Hopefully Amir measures this product in a matter of days.
Matias
São Paulo, Brazil
50W @ 8 Ohm?
Or 130W at 1% THD+N in 4 ohms is quite OK for a bookshelf speaker.
But there is also Hypex NCore NC502MP for $650 and does whopping 600W in the same conditions and still very low distortion and noise overall if you prefer.
daniboun
daniboun
France (Lyon)
Dang that's impressive. @JohnYang1997 got any sneak pics for us?
The amp looks like the PA3s with TRS balanced inputs. I wish I could see XLR inputs instead....
I dont know if it using a power brick or internal PFC smps PSU....
I bet the amp is using the last Merus chips by Infineon (see their site)
pma
Prague
I went through the datasheet, if they use the linked Merus IC, the amplifier cannot compete with Hypex.
abdo123
Brussels, Belgium
It’s just not worth it at all considering this is a garage amplifier with no heat sinking or anything that would allow you to actually draw this amount of power continuously.
With 400$ you can get a class A/B amplifier from Denon with all the necessary heat-sinking, a DAC, a phono stage, remote control functionality with similar power output.
Solveit
What Denon amp you have in mind?
Walter
Or an even closer comparison, at least for U. S. residents, the NC252MP for $500 from Buckeye (which I assume is who you meant, as well).
