Topping PA5 Review (Amplifier)
Azathoth
"Amir gets paid to shill Topping and then shits on other brands"
^What colleague of mine said about this site in general so he would probably say this for this review, and he's an idiot.
Anyways bravo Topping, for topping(nearly) the charts once again. I would go deeper into speakers, but damn I don't have a good place for them yet, and I just bought some passive speakers from JBL, the 305P MKii. Will probably get the next iteration once I have a new house and a proper treated room to fully appreciate what speakers could do, after years of life support on headphones.
Madjalapeno
NH, USA
Mmm. five of these in a nice rack mount would give me ten channels ...
iu
somebodyelse
The pinning isn't allowed in the EU due to IEC 60320, despite it features de C E-sign which is curious enough, we won't see that in EU, only for the US allowed.
Please explain for those of us without access to, or detailed knowledge of, the standard.
abdo123
Brussels, Belgium
@amirm Is it possible to add THD vs Frequency graph @ a particular voltage(s) for the amplifier reviews moving on? For example the Topping Amplifier is superior @1W / 2.83V with regard to distortion (and thus has a higher SINAD score) than say the Purifi Eigentakt Eval1, but the topping goes haywire at higher levels of voltage, even below clipping.
D700
How about some D30Pro love Topping? XLR and double the output. Double the height if needed to fit in that power supply
antcollinet
UK/Cheshire
@JohnYang1997 I take back my criticism. £50 less than expected and measuring not only best in class, but almost best in all classes. I'm still looking for more power though.
If your next release can top 100W into 8Ω with similar measurements, and without putting the price up too much - you'll have a sale here.
mslim
The Black Topping D-01 thing inside the PA5 is the secret sauce? So that no one can "reverse engineer" the secret? Very small part......
F1308
I guess those 100W will need US $899.
Time will tell.
Walter
I was looking at the specs for the Hypex NC122MP and I have to think it was at least one of the targets here. The PA5 slightly beats it in power and significantly in noise and distortion, losing only in the less linear THD to frequency, in a cheaper and smaller package with a volume knob--although I'm not sure how much smaller it really is if you include the power supply. Well done, JohnYang.
tecnogadget
Madrid, Spain
Ok it is very impressive in terms of measurement but does it sounds good ?
It is not because it is technically very impressive that in terms of musicality it will do the job, no ?
An amplifier doesn’t work by magic nor by “ears telepathy” or “musicality voodoo ”, it is indeed an electronic device, that takes a low level input signal and it amplifies it by adding a determined amount of gain.
Thus if we are talking about an electronic machine, shouldn’t we then assert or benchmark its performance by the same standards (using anocher electronic machine for measurements as Amir does) ? Yes we do. Even not getting technical at all, the logic should make sense to any layman.
If it measures well, meaning beyond the threshold of audibility then there isn’t any single reasoning to not sound “fine” nor “right”.
Dennis_FL
Venice, FL
I have that rack ,Gustard ain't fitting on it,in it ,it'll fit around it or under it.
Yep...I see that now. Gustard = 220x50x170 Rack =150x132x43
But the PA5 will fit
F1308
Old power amps lacked volume control, achieved at the pre, is it a need nowadays due to the architecture or anything else, please ?
pma
Prague
I was looking at the specs for the Hypex NC222MP and I have to think it was at least one of the targets here. The PA5 slightly beats it in power and significantly in noise and distortion, losing only in the less linear THD to frequency, in a cheaper and smaller package with a volume knob--although I'm not sure how much smaller it really is if you include the power supply. Well done, JohnYang.
You would need to know output impedance plot vs. frequency. It is very important. Hypex and Purifi show these measurements, @amirm and @JohnYang1997 do not. Hypex datasheets are most trustable to me, so far. Topping still shows some suspicious measurements like this
without mentioning any details like power used. This is a typical marketing plot. I appreciate the results that PA5 has reached in this test at ASR, but do not appreciate some info spread by Topping.
_thelaughingman
@JohnYang1997 Kudos sir. Topping and you have knocked another one out of the park.
