Topping PA5 Review (Amplifier)
JeffGB
Do you mean there would be a roll off of the highs with the Audient?
I have a Focusrite Scarlett 2i4 fully balanced like the Motu, I reckon.
I don't think there is any roll-off in the highs when driving it single-ended. If all this speculation is correct, it would be similar to the linked Magnius review in that the distortion would be much higher because the distortion cancellation of the balanced circuit would not occur. Perhaps John Yang may comment on this at some point.
NTK
US East
I'm confused. The block diagram of the TI chip indicates that each output path is independent. There isn't a differential input stage. Am I reading this wrong?
antcollinet
UK/Cheshire
I hear you but look at the block diagram. That doesn't show any kind of differential input stage.
Block diagrams are not circuit diagrams.
For example, they don't show how the circuits are reconfigured based on the mode input pins for 4xse, 2xbtl differential, or 1x differential pbtl
EDIT - it is even possible the differential summing is done in the PWM domain.
EDIT some more - also the 3255 is not the only device in this amp. It is highly likely (especially based on circuits I've seen on post filter feedback) that Topping have implemented an external differential input stage for the amp.
anotherhobby
wow. It sounds like Formica, high pressure paper laminate but I suppose it's more like vinyl wrap?
Did you make the stands too?
Thanks! Yes, Wilsonite is basically exactly like Formica (not like vinyl wrap). Most patterns would look a lot better on a counter top than on some speakers, but this one happens to look pretty damn good on my subs. :)
The stands are just a set of legs I got here and bolted to the cabinets. I made this thread about the build.
tvrgeek
North Carolinia
All this cancelation is ONLY if there is common mode noise to be rejected. ONLY. Balancing a differential input is actually very hard. I might refer you to the Self and Cordell books on the subject as well as the Jensen transformer site for facts, not assumptions. BTY, using balanced connectors does not prevent a ground loop in all cases.
Roll-off is usually caused by insufficient current to the next stage.
Oh yea, all consumer gear is not floating ground. Bad assumption on Hypex's part.
bartgign
Hello guys
Any advices for a good DAC with this power amp ?
With :
Bluetooth
Balanced
Good ASR Review
Thanks !
daftcombo
What could explain the (subjective?) difference he hears between the MOTU & the Audient then? Impedance output differ perhaps?
Matias
São Paulo, Brazil
The dashboard SINAD for 10 kHz for this amp would be around 95 dB. Better than average, but not as good as for mid range.
2nd harmonic at 20 kHz would be inaudible because of Fletcher-Munson curves.
That is why 1kHz main tone and its harmonics is more used: it is right where our perception is more sensitive.
Matias
São Paulo, Brazil
And again you do not consider intermodulations.
And again you don't consider that musical content is -40 dB at 20kHz and somewhat higher at 10 kHz. Let's see those IMD charts with those levels and then we can conclude something practical.
tvrgeek
North Carolinia
It depends. Live in an apartment and are reasonable about levels. Probably. I just modeled my current Seas speakers, and the SB and CSS I may use for my next build, determined what power would exceed X-Max, and yea, it should handle what I do most of the time. I ran a 40W Creek for a week while I was refurbing my 60W MOSFET and it did OK. Now, if you expect to do live full symphony or just have to crank up AC-DC, then no unless the mains were Klipshorns. If your mains are reasonably efficient, they it just might.
tvrgeek
North Carolinia
What is so often missed is the IM caused by harmonics exciting the tweeter breakup. It does not take much. Won't see that in am amp test into a fixed load, but we can HEAR it.
We also forget, we are not all 30 year old men in England 60 years ago.
