Topping PA5 Review (Amplifier)
HammerSandwich
It probably means you could possibly experience a dip in the perceived volume at 1khz with the speaker using the PA5 if you push the speaker levels?? Possibly affect the perceived tonality of the speaker if it runs out of power at 1khz ??
You have peak/dip reversed here. The amp's maximum voltage will drop at low impedances.
maxxevv
Its about wattage (I x V ) and not just voltage right ?
The measurements say it outputs lower wattage at higher impedances, and higher wattage at lower impedances. So it will probably achieve its at least 83W output at under 4 Ohms but less than its measured 47W at greater than 8 Ohms. Which in this case, the 9.8 Ohm peak at 1 Khz for the speaker, it would be the case?
So if one was pushing the speakers at a level that draws over 70W output nominally, would the speaker behave with a dip in output at the 1khz point clipping at below 47W then ? Since its peak at 1khz is over 8 Ohm ? Would the difference in power output levels be discernible then ?
HammerSandwich
Reconsider this starting from the speaker's frequency response at 2.83V. We often call that "1-watt sensitivity," but the actual power into the speaker depends on the impedance at each frequency.
When an amp can produce 28.3Vrms at a given frequency, it can play 20dB louder than the "1-watt" output. If low impedance at a different frequency limits the output to 20Vrms, max SPL drops by 3dB at that point on the curve, even if the amp's providing more power.
AudioArchitech
edit. @ToriCatcher
IMO, just use a Balanced source with PA5. Especially with speakers below 89 dB efficiency. You’ll run out of steam with inefficient speakers. There’s plenty of other great options that use RCA. ClassD: SMSL, Hypex…
Side note, I tried PA5 with Topping E30 (RCA). When I cranked the volume up (in between tracks) I could hear some noise from the tweeters. Not bad tho, still much quieter than Aiyima A08. When PA5 connected balanced to PecanPi it’s dead silent.
maxxevv
So current has nothing to do with the power since the the output power is just the reverse in behaviour? ?
gfinlays
No, in the example voltage limitation above (20V), the output voltage is limited due to the amp's current limitation. Power output is a function of voltage, current and resistance:
P = IV = V²/R = I²R
With low impedance ("resistance") loadspeakers, power output is limited by an amp's ability to supply current (V = IR). If current is limited, the amp will clip at a lower output voltage. I've used the terms impedance and resistance interchangeably here for simplicity. In practice, we use Z for impedance rather than R. Z is a combination of resistance R, capacitance C, and inductance, L. A speaker is a complex impedance load (it's "resistance" to current flow is frequency dependent, which also results in frequency dependent phase shifts between voltage and current). That's why impedance is normally shown as a graph against frequency. Both impedance and resistance use the same, unit, the ohm.
Toblerone
Congratulations to me! I made it through this entire thread to better understand what was going on with rca cables and the pa5s balanced inputs… despite bsas’s posts constantly muddying everything I was trying to understand. Regretfully in the end I decided to not get this amp due to the balanced inputs. I’m tired of adding more complexity/compromises/rigging (this would be like the cherry on top) and I know I will "hear" it. Almost makes me nostalgic for the days when I had soundbar lol.
Thanks everyone who kept the discussion on track or replied trying to clarify the nonsense going on throughout. Now back to trying to find an amp to stick between my marantz nr1711 and metas…. or just stay with my (always meant to be temporary) aiyima 07.
antcollinet
UK/Cheshire
No more so than with any other amp at that volume.
The voltage from both amps will be the same, so as the impdedance goes up, so the power will drop for both (Amps don’t increase their voltage to give constant power - they are essentially voltage amplifiers. Constant output volts for a given input volt regardless of load - until the impedance drops so low it can no longer deliver enough current.
cfo92130
Paris - France
edit. @ToriCatcher
On my side, I am using a Topping PA5 with Topping E30 (RCA) without any noise on old JBL XTI 80. Sound is very clear with many details.
bartgign
I tested yesterday on my infinity kappa 8A with PA5 and E50. Its OK, around 80 db, i am affraid to test louder.
AudioArchitech
Just to clarify, I was talking about when there is no music playing. No details would be heard, just silence.
gfinlays
Yup, the Benchmark AHB2 costs > 10x the cost of the PA5 and is aimed at a different market (primarily pro-audio which is why they offer 19" rack mount options), so yes, it was heavily tested.
If you're so perturbed by your perceived potential performance issues with the PA5, then why not buy one and test it yourself?
I, like many of the others here, am satisfied with mine. Not had a chance to listen to it back to back with my AHB2 - need to make up some XLR/TRS cables, so I can listen to them both with the same DAC (Topping DX7Pro). I'm also putting together a mahoossive dummy load (225W/8 ohm, 300W/6ohm, 450W/4 ohm) to test them both with REW and to properly test my DK VS.1 Signature MK3 (which is why I need such a hefty dummy load).
After looking at my existing heatsinks, I realised they are woefully inadequate for a 450 W per channel load, even with fan cooling, so I've got a new heatsink coming ( salvaged from a 110 kW Toshiba 3-phase VFD) All 16kg of it :
tvrgeek
North Carolinia
oil bath
antcollinet
UK/Cheshire
This is a very cool dummy load build, but way overkill for my needs. Unfortunately UK hot water elements are about 19 ohms....
3 of them gets you to a sensible speaker impedance then….albeit not 8ohm
