Oh yeh. Forgot that’s it’s through seller.Doesn't matter which amazon you got it from,it's the seller that counts.
Topping were very slow to respond, the guy who worked on pa5 vanished from the forum,Is there a time frame for the fixes.
Is there an actual statement from Topping on this, or are you speculating?Topping were very slow to respond, the guy who worked on pa5 vanished from the forum,
He ignored us all.
Then reappear after a month or so.
There’s a section from topping that said they are addressing the issue.
The pa5 component has o be redesigned.
A component is getting hot and puff....
It’s not just something they can fix. They have to redesign a component for better tolerance.
It’s on this forum. Iam sure , they said a fan wouldn’t help as it’s a component that needs to be re manufacturied. Getting hot.Is there an actual statement from Topping on this, or are you speculating
Remanufactured and redesigned might not be the same thing. (I would read it as replaced)It’s on this forum. Iam sure , they said a fan wouldn’t help as it’s a component that needs to be re manufacturied. Getting hot.
I think these are the posts addressing it most directly. The later post is a lot less definite about having identified the source of the problem.Is there an actual statement from Topping on this, or are you speculating?
So nothing to do with a redesign then.I think these are the posts addressing it most directly. The later post is a lot less definite about having identified the source of the problem.
https://www.audiosciencereview.com/...owners-only-please.33293/page-25#post-1246970
https://www.audiosciencereview.com/...owners-only-please.33293/page-26#post-1247958
https://www.audiosciencereview.com/...g-e30-ii-dac-review.36028/page-4#post-1261614
I talked to couple of audio buddies about it who has stuff like accuphase. To them, part of the music listening experience is seeing the gear they have too and holding the pride that they own something really boutique. They just said no matter how good they sound it’s another class d and they don’t want it. So I am pretty’s sure it’s not gonna hurt any Hi-Fi fans. They live in their own delusional world
Preamps are for adding gain and inputs. You could use a preamp if you want, but I assume if you turned your PA5 all the way up to max your speakers already would be pretty loud.Is it better to use a preamp between a dac and Power amp ? Iam using Ares2 dac balanced output to pa5.
Not unless you need something the preamp does.Is it better to use a preamp between a dac and Power amp ? Iam using Ares2 dac balanced output to pa5.
Didn't review well here - mainly for crosstalk, and "getting damn hot" reasons.I have to say this to peeps in the UK...
While all this angst is going on as regards the PA5, we here could easily sacrifice some inaudible SINAD and try a Rega Io! Sure it's an old fashioned performance (very respectable by low cost 'popular' amps of the 80's and 90's over here), but bearing in mind UK owners of amps like these aren't headbangers and don't use silly-impedance speakers as a rule, I bet an Io would do the job really well at moderate levels and it's serviceable if it did fail in the future...
Has anyone tested to modern standards the 'baby' Denon, Cambridge and Rotel amps recently? we know the cheaper Yamaha integrateds are pretty fine really and reliable and many with 'desktop' systems would by now be using small active speakers, surely?
I look at the PA5 as a cheap little fun-box really. There's just not enough *there* to take it hugely seriously in the wide scheme of things when Crown (and cheaper, Behringer and others) make amps with real power output designed for some hard use. They're not dinky boxes though...
Ah, I thought it was still under £400 (£379 I thought). Rega don't increase their prices unless they have to, so £420 is a large jump, at least for them. I used one for a morning into a moderate load and it was perfectly behaved. Crosstalk I can't defend, but it seems psychologically, as don't seem to mind reduced crosstalk, at least at hf (I can't link to a suitable paper though - so apologies)Didn't review well here - mainly for crosstalk, and "getting damn hot" reasons.
It is also lower power, and higher priced than the PA5 - which would matter, IF the PA5 were reliable.
