Topping PA5 Review (Amplifier)
Open Mind Audio
Baltimore
Fingers crossed my 15-month-old PA 5 is still working 100% fine, with about 3 hours daily use 4-6 days a week. (Set up in desktop config.)
anli
It’s a shame that buyers have to use this unit in fear….
Buyer pays for it and then feels lucky that it still works…
What a pity….
Agree. Am thinking about getting PA5 II, but don't know if it free from issues.
gamerpaddy
Germany
they moved the heat producing components out of the potted modules, the only way they now get heat cycled is by the temperature rise in the interior of the amp. which isnt as strong and you got a little more convection. the potting compound may not contract/expand as much as the "active" module so they should last much longer this way... but if they ever fail its for the same reason. no compound would be the ideal solution. they could just have welded those cans shut and leave air inside to protect their IP without causing these issues
john11
If potted modules are such a bad thing then why have them in the PA5 II
daniboun
France (Lyon)
If done in the state of the art no problem...in the PA5 II the op amps are now "out of the box"
YSC
TBF their implementation is quite in the SOTA ball park in terms of transparency, but then at least I would say it fails in designing with the heat dissipation in mind
daniboun
France (Lyon)
Found this interesting but I have no idea what materials are used in the PA5 II / PA5
Killingbeans
Bjerringbro, Denmark.
It's an attempt at giving the product some allure. "We've designed something very special, that the competition will surely try to copy, so we had to protect it!"
Standard marketing BS, nothing more. Really dumb...
The only good reason for potting is to weatherproof outdoor electronics.
CaptainCoolwater
Check out the SABAJ A30a.
I heard it from a friend against the SMSL VMV A1 and my PA5, Sabaj A8, A20A and A20A 2022. An older Hypex was also there.
The PA5 is great, the A30a is a little better but at least $/€200 more expensive. I don't see any reason why you should take the VMV A1 compared to the two.
How was the PA5 vs A20a?
I'm considering getting the PA5 II Plus or A20a (2022).
gorman
Hmmm... I think the main text of reviews should be updated when widespread problems emerge.
Luckily I decided to check latest posts and found out about the failings.
I would be interested in a similar class of product. Any good suggestions for something reliable?
YSC
My PA5 that i bought in Aug 2022 started having crackle in the left channel today.
it feels like I saw in the Thrustmaster joystick sensor issue: it's not whether it will fail soon, it's a matter of how long before it will fail
Laserjock
Texas Coastal
If I have one of these original units that has never been out of the box/hooked up, is there anything to do that would keep it from developing an issue once I put it to use or is it a luck of the draw kind of issue?
dualazmak
Having read the recent sad stories, I feel and realize the "hopeless difference" between the companies and their QC and liability policies/practices.
Please refer to my post here.
