Triangle Esprit Antal Ez Review (Tower Speaker)
This is a review and detailed measurements of the Triangle Esprit Antal Ez Floor Standing speaker. It was kindly loaned to me by a local member and costs US $2,400 (pair).
The overall fit and finish is nice:
The tweeter though looks odd and takes away from the clean look as does that sticker between woofer and port. The Antal EZ was quite heavy requiring my son's assitance to lift it on top of the measurement rig and then two flight of stairs to listen to (picture above).
I performed over 1000 measurement which resulted in error rate of roughly 1%.
Testing temperature was around 60 degrees F.
Reference axis for measurements was the center of the tweeter. Grill was not used in either measurements or listening tests.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Triangle Esprit Antal Ez Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Triangle Esprit Antal Ez Floorstanding Speakers Frequency Response Measurements.png
The most glaring issues are rather rough bass response all the way up to 600 Hz. Post that we also have a number of resonances but overall response is more of less flat on axis which is good. The roughness in the low frequencies was rather odd and unusual. I *think* I have identified that peak around 260 Hz is coming from the mid-range driver. See these near-field measurements:
Triangle Esprit Antal Ez  Tweeter and mid-range Frequency Response Measurements.png
Same resonance shows in both tweeter and midrange but is much stronger in the latter. Now, that could be low frequency response that gets picked up by the mic in this position. Let's look at the two woofers then:
Notice that the woofer closest to the mid-range shows more of a problem than the one that is farthest (right). All of seems to point to the midrange as the source. But then when we look at the port, we see it strongly there as well:
I am thinking that may still be mid-range bleeding back through the box and coming out the port. What do you all think?
Back to our "spin data," our early reflections are more or less similar to direct axis with some high frequency roll off:
Triangle Esprit Antal Ez Floorstanding Speakers Early Window Frequency Response Measurements.png
Summing the two spins, we get this predicted in-room frequency response:
Triangle Esprit Antal Ez Floorstanding Speakers Predicted In-room Frequency Response Measureme...png
Seems like our problem area is from 150 Hz to aforementioned 600 Hz or so.
Impedance was the lowest I have measured at just 2.7 ohm:
Triangle Esprit Antal Ez Floorstanding Speakers Impedance and phase Measurements.png
You need a proper amp that doesn't mind pumping out current. We also see multiple resonances which we had seen in the frequency response measurements as well.
Distortion goes up around a few of these resonances:
Triangle Esprit Antal Ez Floorstanding Speakers Relative Distortion Measurements.png
The amount of distortion is unacceptably high for a floor standard at 96 dBSPL. We are used to seeing bass distortion but here, but not well above that in such distinct patterns which should have been investigated. The first mountain centered around 250 Hz coincides with our resonance so definitely a cause and effect there.
Beam width shows narrowing of the response horizontally with frequency which is not all that bad by itself:
I expected better directivity vertically given the inclusion of a midrange:
Hard to sit at a level higher than the tweeter so you may need to pointing down to not fall in that hole around 3 to 4 kHz.
Speaker Listening Tests
The first impression was "this is not bad." Power handling was excellent and I could play very loud with any deep bass break up. Then again, there was not much deep bass.
I brought up the measurements and tried experimenting with equalizations. This is very tricky as the response anomalies are in low frequencies where the room heavily modifies the response of the speaker. So what we see in anechoic measurements above may not be what I was experiencing in my room. First attempt at filling the holes around the 260 Hz resonance was a failure. I scrapped that and just pulled down the resonance and that worked well:
I lost a bit of bass response but I thought clarity improved. I tried to compensate again with boosting some of the other areas around it but it just resulted in boominess so I gave up. You would need to make in-room measurements to do better than I did.
As a way of comparison, I put my Revel M16 next to the Triangle on a stand. While tonality and to some extent clarity was better on the Revel, the sound was clearly localized to a smaller source vertically, leaving a preference for the Triangle for the larger, more realistic image it portrayed.
I replaced the Revel with Infinity R253. The R253 was not a match at all for the Triangle. It sounded puny and weak.
Humbled, I took out the big guns and connected the Revel Salon 2 next to the Triangle. :D OK, now were talking sublime sound quality! :D :D Wow, sometimes I forget how wonderful the Salon 2 sounds. I spend so much time testing other speakers I don't get much time with them. The Salon 2 naturally had much deeper bass but it was also so clean and tonally smooth that you just couldn't go back to the Triangle. 10X the price and better engineering was of course at play there.
We have a speaker here with some good qualities but also a glaring issue in bass response. It is as if they took an existing design and yanked out a woofer or something and left the rest sort of unfinished. The problems would easily show up in even DIY measurements let alone the (small) anechoic chamber that Triangle shows in their marketing material. It is a shame they did not go after them to fix it as it could have made for a nice speaker.
As is, I can't recommend the Triangle Esprit Antal Ez. Per my listening tests though, with EQ, it can provide an enjoyable experience though so if you own it, it is serviceable.
  • Triangle Esprit Antal Ez Floorstanding Speakers.zip
hardisj
Reviewer
North Alabama
Thanks, @amirm.
I'm not familiar with this brand at all. I am curious if there are other measurements out there that may show if this is "par for the course" with their designs or if this is just a single bad example of what they otherwise produce.
Rottmannash
Nashville
Is the panther hiding?
Thanks, @amirm.
I could not find any on this model. It is a French company that has become popular with youtubers in the last year for their bookshelves. So not on the radar of many sites to measure it and such.
DanTheMan
When I look at the measurement, I’d think that Infinity would sound much nicer than this. It’s sort of disappointing that you seem to indicate otherwis. Am I missing something ?
The drivers are tiny on the Infinity compared to this so it just doesn't have much presence in bass department. I had misgivings with it when I reviewed it as well.
HiFidFan
U.S.A
Coffee_fan
Thanks for the review Amir. I like the sound of these Triangles, IMO the tweeter is a bit hard on the ears, horns in general cause that to me, but with EQ on the bass, they sound very nice.
Helicopter
Michigan
Thanks Amir. I keep hoping they'll make a good speaker with high enough minimum impedance for the most picky tube amp because of all the subjective reviews, but so far, nothing special from Triangle. A much better French speaker can be had from Focal, and if you want something easy to drive, the bookshelves are good choices.
Reactions: Tks
Coffee_fan
Would've been interesting to hear side by side comparison with something like the Revel M105s which are closer in price bracket to these as the M16 are possibly unfairly beat.
tktran303
Triangle has been around for a long time and is well established in the UK and Australia, and often identified amongst the HiFi press as the “other French” brand.
@hardisj I’ve seen measurements of at least a half dozen speakers from them and measurements have never been outstanding.
in their early days they even lacked baffle step compensation (and thus able to achieve very high sensitivity)
in fact makes their measurements make B&W, Focal etc look good.
Rja4000
Liège, Belgium
I'd really like to see more tower speakers tested, in general.
You need a speaker with a minimum physical volume to reach a reasonable frequency coverage with ad-hoc dynamic range.
A few years ago, I had a chance to listen to the Triangle Signature Delta, and it was an interesting speaker. Far from perfect, but pleasant still.
AndreaT
Commonwealth of Massachusetts
From the last two reviews it seems Triangle speakers have problems with resonance poorly controlled in the integration of cabinet/drivers/ports. Not a good value as Revel in the medium expensive tower speakers group.
alex1berg
Hu
Wha wha wha wha whaaat?
