Yes, of course.
I am using 15 multi-point calibration. One in mlp, 12 points on a circle (~50cm radius) around mlp every ~30°, and 2 points at left & right seats next to mlp.
That's my choice in targer curve, sounds to my ears like "true flat" response: -0.5dB@20Hz, +0,5dB@30Hz, -9dB@20kHz:
Rew checking one random speaker:
Room RT60 :
~1 hour the measurements, 1 min setting the target curve. That's the time needed for calibration..
Basically, it's just an automated multi-point calibration, all settings at default.
No "fine tuning" needed in my case..
After 30 years in high end audio gear endless "upgrading" (just spending money), trinnov is the end.
IMHO: it's as good as it gets.
The rest of my setup:
All 13 speakers are Neumann 310's and all speakers are at exactly the same listening distance from mlp (2.3m) and at the correct listening angle, with cross firing. Center speaker due to screen is 10° lower, trinnov can correct this.
2 Neumann subs (2*10" each) and 2 genelec subs (2*12"each). The genelec's are symmetric positioned with the same distances from boundaries and they are sharing 1 trinnov output (all 16 are used).
The 4 subs are positioned near the 4 corners of the room, at the spots where they measured best (rew checking).
Jvc n7, lumagen, Stewart 117" studiotek 130 g4. Viewing angle at mlp ~50°.
And a mk5 turntable, just for fun.
Trinnov, one audio gear to rule them all..
