Ugliest or Dysfunctional CD players, Turntables, Pre-amps and other gear
restorer-john
Man this has to be a joke??
@Blumlein 88 is right, I looked it up too. My goodness people are gullible.
I won 2nd prize in 1980 in a junior science competition with some PCBs screwed to a piece of wood. I think Iwas 12 or 13yo.
Hayabusa
Abu Dhabi
mononoaware
No Quartz PLL meant it wasn't as stable, nor as resistant to drag.
I remember this being related to how the Direct-Drive motor functioned.
I guess turntable speed consistency could be seen as the equivalent of a DAC’s internal clock, with inconsistent motor speed influencing the timing of the music.
And to my understanding with the Mk2 the Direct-Drive speed consistency was far superior to anything else at the time.
Sure people thought motor vibration was an issue, but it was extremely well made and operated with clock like accuracy. I thought “belt” drive with heat and friction wearing down the belt and needing to replace it was old-fashioned (kind of like Tube Amplifiers).
Found this:
https://www.technics.com/global/home/sl1200/heritage.html
From SL1200 onwards the design has not changed one bit ha.
tomtoo
Germany
"....Conforming to the Vibration & Character chapter the BYOB amplifier has no enclosure, and thus no enclosure resonances. If you knock on it, you won't hear trashy sounds. Just the musical sound of a solid spruce board, that is lacquered with natural wood resin....."
I see, if you knock on a amps case and you heare a 'ping' thats bad for the sound the amp amplifies, so better no case.
Great idear to sell a amp without case, more expensive than with. :facepalm:
I would say another case of hifi voodoo bla.
FrantzM
Altmann Attraction DAC. Yes on a piece of wood is how it came from the maker. You had to supply your own battery. It cost over $3000 for one that worked at 44.1 khz/16 bit only. For several hundred more you could add other sample rates and 24 bit.
This needs to be a sticky for any of the High End Audio extrme BS threads ... triple WOW! :eek::eek::eek:
Went to their website and ... wait ... there had more
I thought , I had seen it all in High End Audio. This has to be one of the ... <words are failing me... I can't find any superlative or expletive for this > concept I have ever seen. Defintely top 5.
http://www.mother-of-tone.com/byob.htm
Marc v E
The Netherlands (Holland)
If I remember correctly, it was attached to a piece of wood because " wood sounds good". Tuned like an instrument ;)
tomtoo
Germany
From marketing point of view it's genious.
Sell less and make the people feel they have more!!
Soniclife
With the technical side sorted if you then focused on creative writing you would be rich by now.
Dialectic
a fortified compound
Everything that was made by Blue Circle Audio.
