- Thread Starter
- #21
Let me test it with the Schiit Modi 2 DAC tomorrow and see if there is any news on that front.Does the LPS-1 have any real world benefits , leaving behind this particular leakage issue?
Shipping weight and cost, need to meet product price point for maximum sales.
edit
Sorry misread thought you meant SMPS v linear supply
It will only add benefit if the device its powering has inadequate PSU regulation and filtering. However if thats a real problem for you you need to buy a different DAC. A very quiet PSU if required can be realised quite cheaply, you dont need to spend $400.
The logic of the product totally eludes me. Why would you spend $400 on a psu that (allegedly) improves your inadequate dac. Sell your inadequate DAC, add the $400 and buy a decent DAC!
Excellent points. It is comparable to a megabuck amp or preamp needing a different aftermarket power cord than what is supplied for a supposedly awesome performance improvement. Placebo and expectation bias can work marketing wonders, even when there is a return privilege.This is all starting to look about as necessary as bottled water, except some live in areas where you really should not drink the tap water but DAC's unlike the mains water are easily changed so best do that rather than buy stuff to fix it.. stuff that infact might actually do more harm than good.
I have to say, if I was a audio engineer making top dollar DAC's , the cost no object variety ( or even just damn good ones) I'd be insulted to be told some guys think my best design can be improved by sticking a $300 widget in front of the USB port, if it did turn out to be necessary I think I'd consider a career change lol .
What do the guys at DCS or TAD labs or Berkeley etc think about being told their best work needs these kind of extras to be any good? Or even just that it's so simple to make their products sound better?
You have got to be either fairly arrogant, drunk on your own kool aid or a total genius .
Just what I think mind you so take with a pinch of salt.
Since the first day I have measured their products, they have talked about internal measurements they have done but none ever comes out.JohnSwenson take on LPS-1 at CA:
"I have built a power supply leakage tester, again a single number is not nearly as useful as a leakage VS frequency graph. When I put the LPS-1 on the tester it shows a flat line right at the absolute floor of the tester.
Alex has a policy of not showing measurements of his products VS named products of other companies so I will not say how that compares to other specific supplies. I can say that nothing else I measured comes close.
I don't have a good way right now to calibrate these graphs to come up exactly what those leakage currents are, but I CAN say the floor of the tester is about 500,000 times lower than the maximum leakage I measured, the LPS-1 is going to be less than that."
https://www.computeraudiophile.com/...and-microrendu/?do=findComment&comment=706929
I must say, it surprised me too given how much they have talked about LPS-1 providing this isolation.OMG! This one too. I thought at least this one was worth the shot with all the isolation from mains, breaking ground loop, etc etc. It did make it to my wishlist as well but....
I think they/Alex firmly believe it improves audio by doing subjective listening and believing in improvements they think they hear. It is absurdly easy to go there. Use the presumption that power/USB is cleaner and you automatically hear more detail, less haze, etc. The only way to know if this is really happening is to do so without knowledge of the device being in loop or not. I don't believe they have ever done a blind test.Honestly I have to ask why would a company spend time, energy and effort to make a product that doesn't improve audio ?
You mean like the farmer with a box full of dirt approach. I don't know technical stuff or how it works. I just know it sounds good. Buy my box and see if you don't hear it sound better?I must say, it surprised me too given how much they have talked about LPS-1 providing this isolation.
Which would be fine if they just said that. They simply need to get rid of everything they say technically as the reason for the device improving audio. It is those technical details that are not holding water.
The moment they talk about measureable electrical characteristics, we can quantify them.
Their entire marketing campaign relies on technical arguments however so they are caught between a rock and a hard place.
I love to know now, with full knowledge that this device provides no isolation or improvement in the DAC output, whether the current owners have second thought about improvements they think they are hearing.
I suppose you can say the resolution post Regen is so improved you now hear USB cable differences more clearly even upstream. Makes no sense technically, but the customers aren't technical people. It is easy to picture in their mind. So now a better Regen will make that even clearer requiring even higher quality USB cables which now will be audible.
I am telling you, if Alex can swallow his ego a bit, he can use your measurements for John to whip up a superior power supply, acknowledge your assistance and make more money than ever off the deal.
Well, the people who loaned me the equipment do.No members over at CA has any 2nd thought on Uptone products.
There are no standards for measuring power supplies. Results only make sense if they are on the same workbench/test. So nothing I produce can be compared with Daitron specs.Since the LPS-1 is supposed to be a universal power supply, not just something to power ISO Regen's, it would be nice to see the measured results of the supply itself. All of the measurement results Daitron provides for their supply would be a good start.
