The power supply is internal, not an external brick. So I am assuming the plates have the correct voltage. I think your referring to the tubes that are more decoration than functional?Do the tubes run on low plate voltages?
Not needed, I have voice recognition internally programed since childhood.Does it come with voice recognition?View attachment 15403
It sounds fine. No hum.
Built like a tank to. Looks like something you would take to a Lan party. Its got the same kinda build like the Factual Define R5 PC case below it. Very similar. The metal, paint,shape of it. Looks like the top and sides are one piece secured by screws and it can be removed for access to the guts..it looks like a very interesting product with adjustable impedance, and can run as pre-amp too!
hope amir will be interested in measuring it in the future
