Who is the father of this child?
Purité Audio
Industry Insider
Barrowmaster
London
Phison Audio - Sonny
Industry Expert
Volume control: ad5543brmz + ada4627-1
7.4 to 5.5V converter is tps62150
Level translators for dac and riaa txs0102 txb0104
Front panel led controller pca9955b
Industry Expert
Adg5543 was chosen for its bandwidth of 6.6MHz (low bandwidth means poor attenuation in middle range and up) and low resistance r2r network 5k
RayDunzl
Central Scrutinizer
Riverview FL
tomelex
So called Midwest, USA
TECHNICAL SPECIFICATIONS ((((( R E A L L Y ?? excuse me for asking!!!!)))))
Type: integrated amplifier
Inputs: Three line-level single-ended stereo pair RCA analogue inputs, one stereo pair RCA inputs for phono, two S/PDIF Coaxial digital inputs with RCA connectors. One Toslink S/PDIF connection. USB B.
Outputs: Five way loudspeaker terminals
Digital formats supported: (USB and S/PDIF RCA) PCM up to 24-bit, 192kHz. (S/PDIF Toslink) PCM up to 24-bit, 96kHz
Power output: 300W into 8Ω, 600W into 4Ω At what frequency range and what percentage of distortion?
Attenuation: 100dB to 0dB in 80 steps
Frequency response: not specified Kidding me?
THD+N: < 0.005% (1-100W, 8Ω) What happens at less than 1 watt and greater than 100W?
IMD: 0.0008% What standard is being used to measure this?
Dimensions (W×D×H): 44×37×10cm
Weight: 16.5kg
Price: £20,000 There is nothing unique about this other than the way it looks
Manufactured by: Aavik Acoustics
Huh! Never seen someone limiting the power range this way. They are stating where there distortion+noise is the lowest.
Sal1950
The Chicago Crusher
Central Fl
After 37 years my mum is still asking this question...
Industry Expert
Hi, dont trust the website.
Some of the data is taken raw from the M2-PRO datasheet. The frontend is there fore not taken into account.
Line level signal bandwidth is reduced to~700KHz before the class D module. There are several low noise voltage regulators onboard for each stage.
I would suggest read the german reviews.
https://www.dropbox.com/s/qp0l1lz1wk0ry5p/Aavik_Stereo_15.pdf?dl=0
Take the worst measurement: Hifi and records.
https://www.dropbox.com/s/5ioct3ie33yv6x4/hifi_and_record_august_2015.pdf?dl=0
But it still makes me sick to read the reviews!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Sonny sorry for my lack of language but what does the review say?
BW Keith
Sal1950
The Chicago Crusher
Central Fl
