FWIW
I gave up on my Wiim mini at the end of the day!
I loved it at first, but in time I hit a road block, perhaps not totally be blamed on the Wiim, but a block never the less.
My problem was, that as well as my own local files, I needed to route streaming services to the Wiim. Before I go any further, for local files, Wiim worked perfectly, I mean, I could use it no problem.
You see Wiim is just the end point, the server needs to be able to send it correctly too, THAT was my issue.
It seems, serving live sources (live streams) is not as easy as playing local files. On Android, my trusted Neutron media player, could happily send to Wiim mini, and on Windows laptop, Jriver could easily play local files to Wiim mini.
BUT ....
Live sources, live broadcasts or live-streaming is another matter.
Ofcourse I know, Wiim app can manage a few streaming services, but I needed to apply my own DSP to it first and then send it to Wiim.
I found a neat free app, called
"stream what you hear" that would (could) stream whatever you are listening to an endpoint, but not Wiim! It can send to just about any other software based UPNP player, but not Wiim.
At the end of the day, I realized that there is a simple method of replacing the Wiim with a software player, have my cake and be able to eat it too.
An old PC or an Android device connected to my DAC, with a software UPNP player.
A dis-used Android phone (need not be that powerful), and Neutron media player installed, setup as Media Renderer can do just about everything I needed and more.
Or a small PC with Jriver installed, set up as renderer.
- Just about any Android or windows player can play to them, as they show up as UPNP/DLNA players.
- Stream what you hear works with both, so live streaming is possible.
- Both Neutron and Jriver have powerful DSP engines, so I could implement my room correction at the renderer point.
In case of an Android phone, it would be no bigger or more expensive than a Wiim.
BTW, wiim does have a feature to add network stream to it, but it sort of didn't work for me.
