WiiM Mini Streamer
rarewolf
Are there any audible differences between using TOSlink (Mini) vs coaxial (Pro)?
I’ve heard of “jitter” problems with optical, but what does that sound like?
Jmudrick
Toslink jitter will be a non issue with any competent DAC. The only difference, likely inaudible, might be the ability of the coax to handle resolution greater than 192..
antcollinet
UK/Cheshire
Unless you are sending it to an incompetent dac it doesn’t sound like anything. even if you are it most likely still doesn’t sound like anything.
rarewolf
My Topping DAC is certainly competent. I believe my problem is that I cannot quite accept the Mini as real… as in, “too good to be true”, and that I should have spent a lot more than $100! The damn thing is so practical and functional, I figure something has to be wrong with the sound quality…
onlyoneme
Poland
Well, Patek watch will not measure the time better than Casio. But yes, you will find people who say that WiiM's SQ is worse than X, Y or Z.
rarewolf
I had to look up your reference to “Patek”… #HAHA
How much worse could it be? I’m only using it to stream PCM (even if I do wish it were USB)…
On another note regarding functionality: Once installed and configured (via WiiM app and Bluetooth) for using other player apps and pointing them at the WiiM output device, I don’t any longer have to use Bluetooth. JRemote simply and transparently works, short of a small delay for the 1st track.
onlyoneme
Poland
From my perspective you will get exactly the same audio quality over toslink from WiiM to your DAC as with any other bit-perfect capable transport. As long as you stay away of EQ in the WiiM.
There are evident drawbacks of low WiiM's price - overall build quality is not the best, toslink socket is fragile, analog audio section is at the budget line, jitter could be lower but clock components are probably far from perfect. None of them affects audio quality when connected to your DAC. Ok, avoid unplugging your toslink cable frequently...
Witterings
New FW update, 4.6.503558.
Well that's worked like a POS .... Every 5 minutes it goes silent, the slider bar in Amazon on my tablet is still going across, I have to stop casting and then start casting again ... totally unusable in it's current state.
Whilst I appreciate they're doing their best to improve it at least F**&&g test it adequately before new FM updates ar released.
Some people don't mind being the guinea pig / tester but the majority have no f....g interest what so ever and just want it to work.
People say .... send them a ticket .... I'm sorry I have better things to do with my life than keep sending them tickets.
amper42
People say ....s end them a ticket .... I'm sorry I have better things to do with my life than keep sending them tickets.
I had the same issues. I would avoid this firmware version.
onlyoneme
Poland
Haven't noticed but I simply didn't listen to AM today.
Edit: I have no such isssue.
imral3
I am experiencing no issues listening to complete albums on AMHD.
imral3
Did you get release note on 3558?
Bamyasi
Much of this frustration should go to Amazon since this kind of things happen periodically on all of my Amazon devices, not just WiiM. Amazon seems to upgrade the API on their servers and then let them stay out of sync, breaking havoc for the Alexa clients. I guess with such a massive infrustructure some level of instability is expected but it can be really annoying at times.
rcstevensonaz
Expected yes, but that is only because they choose to allow instability — it is not "inevitable". There are incredibly large, complex infrastructures that dwarf the size of Amazon Music yet deliver close to (or above) five 9's for decades on end.
