WiiM Mini Streamer
fquails
You might also try JPlay on iPhone, iPad or Windoze. A bit overpriced, but perhaps worth it for you.
Thank you! I am happy so far with mConnect, having used it for just a few hours. I will try JPlay if mConnect causes problems. The subscription for JPlay makes me hesitant…
Ralph_Cramden
Yeah, it has a nice UI, but the subscription is almost as bad as Roon’s, without anywhere near the features.
Sergauskas
Hello,
Has anyone seen the Wiim mini main board pbc/boardwiev/datasheet?
The owner connected a 12V power supply, as a result, the Wimm does not work. When examining the board, burnt components are visible, but I can't find a datasheet on them.
Merifon
Bulåggna
Hello,
Try to post on wiim forum also. Guys from WiiM usually read and answer.
Brantome
Hello,
I don’t think that a datasheet is available but if you a Google image search for “WiiM Mini tear down” you’ll see a few pics online, for example at https://www.diyaudio.com/community/threads/wiim-pro-information-requested.393202/
You could try raising a ticket to WiiM via the settings/feedback section in the WiiM app, but I don’t know what they’d do in the face of such clear user error and operation of the unit outside its published spec.
