Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,237
- Likes
- 5,477
Let's hope the WiiM Ultra won't have an ultra high price ...
You can control volume through the Pro plus.Possibly a dumb question so please be graceful and patient with my rookie understanding...
If I pair a WiiM Pro Plus (using it for ADC from a phono stage, DAC, and streaming) with Adam Audio active monitors...do I have to manually control volume on the backs of the speakers, or can I control volume through the WiiM Pro Plus?
Would it work also with Neumann KH120 II ? Because it has a built in DACYou can control volume through the Pro plus.
Yeah, the volume control is digital.Would it work also with Neumann KH120 II ? Because it has a built in DAC
How do you avoid double conversion ?Yeah, the volume control is digital.
I'm not sure what you mean, sorry.How do you avoid double conversion ?
WiiM->Coax->Neumann.How do you avoid double conversion ?
Could you recommended a specific cable ? ThanksWiiM->Coax->Neumann.
Audio is only converted once inside the Neumann.
As I don't know which country you're in, no I cannot.Could you recommended a specific cable ? Thanks
QED, Mogami...Could you recommended a specific cable ? Thanks
No, the only reason for getting the wiim is if it offers services you need that are not available on the blueos system in your avr.having this could improve the overall quality?
I don't think it can.Sorry i got a question i got an avr with Dirac live and the bluos streamer integrated, having this could improve the overall quality?
I've just read the review. They are not great, but if you don't run at full volume, they are not unbearably bad. Good enough to sound fine in real world listening. Probably still transparent for most people.i know that my avr measurements are bad as i got a nad 758
Audible impact compared to what?If I use the Wiim pro plus as a preamp, connecting it to a power amplifier via rca, will it have an audible impact in sound quality?
Highly unlikely.Compared to an analogue pre-amplifier with a volume knob.
