Amplifier measurements may require improvement
Status
Not open for further replies.
Djano
France
I apologize if this message should have been posted elsewhere. I couldn't find a "Complain about X measurements" thread, as we see with headphones or speakers.
The Fosi V3 measurements provided by Amir did not highlight a defect that was nevertheless observed in the measurements offered by Scientific Audiophile (video, from 20:00).
S.A. discovered that the Fosi V3, when heavily stimulated, exhibits irregular response across the frequency spectrum. The main issue is that it noticeably collapses below 145Hz, whereas this problem is not observed beyond that point. Here is his graph comparing the V3 to a more traditional class AB amplifier :
I suggested to S.A. to conduct another test to verify his hypothesis that this result can be explained by the fact that low frequencies require more power. He seemed interested. These questions have been discussed here and in the comments section of S.A.'s video.
Therefore, it seems to me that tests should include a power test conducted across the entire audible spectrum. The frequency response appears to be subject, in addition to load dependency, to a "Watts dependency" (?).
I am clearly new to this field. Did Amir's measurements allow for the prediction of this defect in a way that I am unaware of?
I am already very grateful for the time Amir is willing to take to collect and make so much interesting information available to everyone. But we should not miss an opportunity to improve the protocols if they have indeed fallen short.
D
Djano
France
What? Something could happen differently outside of a controlled test environment?
The problem doesn't seem to me to be that the test yielded different results from those in the real environment. The tests simply omit an important aspect of the real use case, which appears entirely possible to test.
Even when tests measure something that doesn't correspond to what happens in real-life situations, it's important to understand why. This allows for improvements in testing protocols to better predict what will happen in actual use. That's the exact purpose of tests.
One cannot simply say, "tests are not real life, kid!" At least, I don't see the point in doing so. This implies that tests don't truly inform us about the real-world performance of devices (which is false) and don't bring any improvement.
fpitas
Northern Virginia, USA
Odd comment. He already does that; for example:
fpitas
D
Djano
France
It clips, so what?
That could be an explanation, but tests should make it predictible to be exhaustive.
S.A. thinks (but is it true?) that the 89W power limit @8ohm before clipping does not suffice to explain what we are seeing.
A graph in this looks like what I was thinking of, yes. However, it is quite rare to find this sort of graph.
And the graph talks about y=THD+N x=freq. response.
It does not talk about output power (SPL would be even better, but different methodology), but about output "quality". Both could cross with notions like clipping, but the culprit could be something else, maybe
voodooless
Netherlands
Well, then he should investigate some more. Just look at the waveform of the audio. Clipping should be evident there, even if recorded by mic.
D
Deleted member 48726
Guest
Should it be expected to clip though? And which test parameter would show the probability of clipping? We would need the load impedance / phase graph and at best a signal oscilloscope trace.
Most likely that's all it is.
IPunchCholla
I'm not going to spend 25 minutes to find out very basic information. This is why I hate videos. What is the testing protocol? It looks like we are talking about measuring an amplifier through in room response of SPL? So I need to know a few things to find out even if I should bother with the results.
D
Djano
France
He uses a sweep signal. Yes, he measures speaker sound output (SPL) in room
IPunchCholla
OK, so we need to know a lot of things then. What are the characteristics of the speakers? This could be an expected result if we just know the specs of the amp and the specs of the speakers. How does he control for variations in mic position (bass will be very susceptible to this)? What are the measurement to measurement variations?
D
Djano
France
Tannoy tower speakers 8ohm, but I don't remember anything else.
Non-issue I think. Just leave the microphone, do not touch the speakers, and plug the bananas into the other amp. I do not see why he would have done differently.
Good question. I guess slim as treble look alike on both amps. But maybe treble is less susceptible to variations ?
I have to go, and will read later when I can
SSS
Germany
Another Junk video without clear methodology. There are many non-controlled parameters when measuring an amplifier over loadspeaker via microphone. The result says nothing. Maybe the Yahama amp graph version is bad too.
D
Guest
It's not. You can literally see the graphs compared in the OP..
I can't see nothing wrong with switching amps and setting outputs to match and then doing sweeps.
pma
Prague
There is a very simple method to find out what is happening - record not only acoustic SPL, but also amplifier output voltage at speaker terminals. This would give an answer immediately.
Status
