Are these measurements OK?
FredC
I own a pair of Paradigm Reference 30th Anniversary Inspiration speakers.
I bought them new 4-5 years ago after listening to them at a reseller and auditioning a bunch of other speakers. I have to say I'm happy with them and I'm not planning on upgrading for some time but since reading ASR for two years now, I have gotten curious about "how they measure" and if there are areas I could improve with EQ.
I have found the following page with measurements: here
If they measure good, fantastic, if not, why and how could I fine-tune this?
Thanks in advance!
Setup
Microphone measuring position: between tweeter and midrange
Grille: off
Frequency response and sensitivity
Sensitivity: 88.1dB (averaged 300Hz-3kHz, 2.83V/1m)
Chart A: 20Hz - 20kHz (measured @ 2m, plotted @ 1m)
Top curve: on-axis response
Middle curve: 15 degrees off-axis response
Bottom curve: 30 degrees off-axis response
Chart B: 20Hz - 20kHz (measured @ 2m, plotted @ 1m)
Top curve: 45 degrees off-axis response
Middle curve: 60 degrees off-axis response
Bottom curve: 75 degrees off-axis response
Listening window
Response curve is an average of five measurements: on-axis, 15 degrees left and right off-axis, 15 degrees up and down off-axis
Total Harmonic Distortion + Noise
Chart A: @ 90dB, 50Hz - 10kHz (measured @ 2m)
Top curve: frequency response @ 90dB SPL
Bottom curve: THD+N @ 90dB (50Hz - 10kHz)
Deviation from linearity
Chart A: Difference @ 90dB from 70dB, 50Hz - 20kHz (measured @ 2m)
Impedance magnitude variation
Vertical axis: impedance
Horizontal axis: frequency
Electrical phase
Vertical axis: phase
MakeMineVinyl
Santa Fe, NM
They might sound a bit 'polite' with the depressed response in the 1-5kHz region, but I suspect this is not a big negative. Depends on the music you listen to mostly.
RayDunzl
Central Scrutinizer
Riverview FL
How they measure on the test rig, and how they measure in your room can be two different things.
Example:
JBL LSR 308
In my room:
In my room with corrective EQ applied:
F
FredC
Wow, indeed. I guess I need to go buy a microphone then. I listen to them near-field but it probably doesn't mean much.
RayDunzl
Central Scrutinizer
Riverview FL
Near-field should reduce the effect the room has on what you hear.
But, I wouldn't dissuade you from measuring if you want to.
The above measure with a UMIK-1 and REW software.
thewas
The measurements you posted show a imho quite clever tuning for their directivity so I personally wouldn't do significant equalising except for room correction in the modal region unless you don't like their tonality which doesn't seem to be the case.
