- Joined
- Mar 1, 2016
- Messages
- 798
- Likes
- 1,597
Indeed you do misunderstand it completely.Apologies if I misunderstand and ask for clarification.
Windows Audio simply sees all audio devices.
If your media player is designed so, you can choose ASIO or WASAPI/Exclusive. This gives the media player exclusive lock on the audio device hence it can apply automatic sample rate conversion.
You still see it in the Win audio panel but if this media player is playing, no other apps can access the device.
Something you can simply check yourself.
Probably because you run a sighted test.Probably because I play through USB
