Problem I have a topping d10 DAC....I install ASIO drivers and it gives me an error message!
Sokel
Ok,I see you have not installed ASIO+DSD,instead you have installed foo_DSD ASIO.
No.
Delete everything,unistall foobar and evry component left,install only the two components I have in the other thread.
This:
and this:
No other additional ASIO,nothing.
Topping drivers are fine.
Set them up as I have them in the thread and you must be ok.
You must know that to play DSD all levels must be at 100% so if you don't have some other way (analog,etc) to control volume maybe thats not for you.
G
glintscollide
No.
This:
and this:
okay....but the topping display don't gives me frequency and dsd segnalation....it remains pcm....is it right?i repeat when i've used jriver...there was display changing for dsd....
Sokel
Wait now cause I suspect something weird here.
What kind of files do you use?
PCM or DSD?
G
glintscollide
dsd of course....dsf ones...i repeat jriver read them correctly and topping display was functioning!
Sokel
Please check your list of programs for any remains of foo_dsd-asio,Asio proxy and stuff and get rid of them.
Make sure they don't appear at your ASIO page (your screen shot 4).
And post a screen of it and SACD to see if something is off.
(Also make sure DSD processor is off and the same with any resampling either on foobar or global)
G
glintscollide
now reinstalled like you say...
but i have to use 24 or 25 configuration?
both functioning but the display on topping stuck on 44.1! :(
i have no more screenshot 4 configuration...and no more SACD on the left as you see yourself...
G
glintscollide
no...no...wait a moment!
i have the SACD section...
as you see i can choose...dsd...ddd+pcm...dsd
if i choose pcm i hear music and the display stuck on 44.1
if i choose dsd i hear only white noise and background feeble music and the dsiplay is perfect 2.82 dsd...all i changed everywhere is only white noise!
Sokel
That means that your level (windows?foobar?DAC? ) is not at 100%.
To play DSD it has to be at 100% everywhere.
Sometimes,MAYBE can work by controlling DAC's volume control.But usually not,you have to have an analog volume control somewhere in the chain to work right.
24 config is the right one.
G
glintscollide
okay i will go to the top of the volume....and let's see...topping has not hardware volume...
G
glintscollide
hoooorrayyyyy!!!!!is gone!!!!victory!!!! :)
i've even played a dsd 1024 that virtually is not supported from my DAC TOPPING D10S from an audiophile site!!!!
Sokel
What did you do (or not do) to make it work? :oops:
Exactly what I told him without a gazillion of add-ons.
Plain foobar with two components and all levels at 100%.
Reactions: Zek
