And yet they could drive real speakers better than many of the absurd, and absurdly overpriced, "audiophile" amps of the time, such as conrad-johnson and Audio Research. That was probably also true of the original Quad 405.
The one single thing we have to thank Naim for was the opinion that an amplifer had to drive an often complex speaker load with a music signal rather than one frequency into an 8 ohm resistor on a test bench. Having said that, Naim also made some popular but huge clunkers of amps, the NAP 90's, 110 and Nait 3 being classicly awful gutless devices (the 110 was harsh from new and stayed that way) which only really sold to get people on the never ending upgrade ladder that Naim specialise in to this day, especially if you go active. The Quad 405 in either marque was far too small* to allow higher current output continuously, so they apparently optimised it for 6 ohm loads which seemed ok for their by then increasingly fragile (as the music tastes changed and amp power increased) '57' speakers which eventually had their own limiters fitted (originally you had to further limit the current output in the 405). They genuinely couldn't understand it seems, why speakers were becoming so much more difficult in terms of loading, but behind the scenes, the mk1 405 boards went through several changes of layout at least, the final mk2 version being I think, 'issue 10 version 7' if memory serves.
* Into my ATC 20's, a freshly updated to mk2 405 regularly cooked itself, getting very hot on top indeed (I didn't *think* I was thrashing it
Quad carried on in the back-room and came up with the hugely better (for good music at higher power levels) 'pro' 500 and 606 family of amps which continues today in the (excellent to me) Artera power amp and QSP. No competition for the likes of the Benchmark or third party Hypex/Purify builds I'm sure, but a good known and solid performer which in early versions (606) only put me off due to appearance! I'm assuming Amir used his large amp to drive the ATC's, as it's my experience the passive ATC's needed something like a Quad 606 power output at least.
