yep, Im between the 2 amps as well. Thinking buckeye due to their appearance on here. Not purchasing just yet as it will be a second system so funding considerations at the moment….I have exactly this - Wiim & Flex in a small room - but with the Buckeye amp in a Ghent case. Also a Topping EX5 for headphone use. Only 1 sub though. I love my setup.
I have a question. Here in the US voltages are 110. If one uses a 220V plug will the amp produce more power?It does. 1% is -40dB and it's right on the nose.
Also, minor variations in mains voltage will cause variations in measured output. The power supply in reality switches in a voltage doubler for US supplies.
I only tried it once and it produced very little voltage so I didn't push it more.As the Hypex NC250MP is rated for 2 ohm operation, does this mean this amp failed at 2 ohms?
With a resistor (2ohm, 0deg), or with a +/-60deg inductive/capacitive component added? I guess the pure 2ohm resistive should work?I only tried it once and it produced very little voltage so I didn't push it more.
Exactly. Could not say it better. Just to mention, “tailored” tests are quite time consuming.Always good to know whether the test may be limiting the outcome though.
Very nice. I'd go for the 2 x mono version, so each can go close to the speaker with short speaker cables. They would be easy to hide it you wanted. <https://www.audiophonics.fr/en/powe...-mono-ncore-nc250mp-1x250w-4-ohm-p-14445.html>This is a review and detailed measurements of the AUDIOPHONICS MPA-S250NC stereo Ncore class D amplifier. It is on kind loan from a member and costs 415,83 € tax excl. (US $444).
The enclosure is absolutely adorable! While it is fair bit deep, the other two dimensions are quite small. Combined with the low weight of the unit, you feel like buying a dozen to spread around the house and two to take on the road with you! The power button feels quite nice. The rear terminals exude quality and would rival and beat what you find on many expensive amplifiers:
Nice to see trigger input as well.
Inside a Hypex NC252MP amplifier module with integrated switching power supply. In use the bottom front got somewhat warm but nothing of concern. Protection circuit is robust and auto recovers from overloads.
If you are not familiar with my amplifier measurements, I highly suggest watching this video on amplifier measurements.
AUDIOPHONICS MPA-S250NC Measurements
Let's start with our dashboard:
That is very competent performance as far as noise+distortion (SINAD):
Zooming in:
Noise performance is excellent:
Class D designs can suffer from load dependencies but we can count on Hypex modules to be free of this:
Crosstalk is very good despite both channels being on the same module:
Multitone test showcases the low distortion:
Dual tone 19+20 kHz shows the same:
Only a couple of sidebands are visible at -98 dB and lower in audible band.
Power curve was very clean with 4 ohm load:
But strangely rose a bit with 8 ohm load:
Back to 4 ohm, we almost get the specified level of power:
I was pleased with rather smooth power vs distortion vs frequency:
The MPA-S250NC passed my stress test with reactive loads of 4 and 8 ohm but shut down into 2 ohm:
There is fair bit of pop on and off noise:
Finally, the amplifier is stable and ready to go on power on:
Audiophonics has produced one adorable stereo amplifier! I just want to sit there and look at it. Fortunately beauty goes beyond the skin, sporting a performance Hypex class D amplifier, producing top class results in all the measurements. You get near state of the art performance at bargain prices with scant space needed to dedicate to the amplifier.
I am happy to recommend the AUDIOPHONICS MPA-S250NC. Can't stop smiling.....
Yes, it's hard to tell from the photos but it's only 141x357x65mm.I replaced that same Parasound with one of these. I actually laughed out loud when I took the Audiophonics out of the box. The Parasound weighs about ten times more, and is four times the size. You can put one of these things anywhere.
Thanks for this. Another question, how did you connect the three to the Denon trigger? If I have one trigger out and two amps, what's the best way to split?I have three of them that trigger on when I turn on my Denon X8500H and I hear no pop.
No because the power unit in the amp sees to that the amp stage is fed the same voltage whatever the mains.I have a question. Here in the US voltages are 110. If one uses a 220V plug will the amp produce more power?
https://a.co/d/97gNDeo and two trigger cables. And actually for my three amps, I bought two of those splitters.Thanks for this. Another question, how did you connect the three to the Denon trigger? If I have one trigger out and two amps, what's the best way to split?
No, it does not have regulation. You may have 100-120V or 200-240V, switchable. And output power depends.No because the power unit in the amp sees to that the amp stage is fed the same voltage whatever the mains.
NC252MP is auto switching and there is no sign in specifications of output power being qualified vs. mains voltage. So, no
The original question was if the output power would vary with mains voltage 110V. And it would, someone may have 105V at home and the other one 115V and they will measure different maximum output power. Same here, I have 240V and my amp thus gives higher power than if someone has 225V at home. This is the key, with Hypex SMPS the output power depends on actual mains voltage."Features: Auto-switching (115/230V)"
So, no. The specification is maintained for both mains types. That was the original question. Why complicate things?
