dtaylo1066
- Joined
- Jan 12, 2019
- Messages
- 662
- Likes
- 833
Old product that had a bit of a audiophile cult following in the day. I think that MiniDSP pretty much put the hammer down on that.
The jitter measurement show about 88 dB. Maybe low enough, but modern dsp crossovers like Minidsp flex has 135-140 dB.I'm pleasantly surprised. That's good functionality for the price. 100db down is fine for anything I listen to.
I used one of these years ago in an active setup.What kind of EQ are we looking at? flexible enough for room correction?
Well , if you need a Ton of PEQ filters it might run short of memory , but in my set up 3 way cross , i was able of puting at least 5 filters on each way and still have a 21% of memory free.I used one of these years ago in an active setup.
The issue I found with the PEQ is that much of the available processing memory was used up in the crossovers and if I recall correctly, only maybe three PEQ filters could be applied with the remaining memory
Yes; and maybe it was my imagination, but sometimes I would hear some odd sounding stuff when there was a lot of EQ in place, like the 8dB second order shelf for the SEAs drivers. Still, the thing is a bargain and I easily got my money's worth.I used one of these years ago in an active setup.
I think that's essential, as an amplifier fault can destroy tweeters and midrange drivers. Bass drivers can take more abuse, at least long enough for any fuses to blow in the power amps, (assuming there are some!) I use normal bipolar electrolytics for protection, as they should have very little voltage across them in normal use, so don't see the point of paying more for film caps.What i now considering is the addition of caps in the tweeters amp output , just to protect them in the event of a DC .
Thought on mkp or even film cap at 20μF for each tweeter.
What do you guys think?
The turn-on and turn-off thump from some amps can destroy delicate drivers, too.I think that's essential, as an amplifier fault can destroy tweeters and midrange drivers. Bass drivers can take more abuse, at least long enough for any fuses to blow in the power amps, (assuming there are some!) I use normal bipolar electrolytics for protection, as they should have very little voltage across them in normal use, so don't see the point of paying more for film caps.
All the amps sansui B2301, B2302, AUX-911DG , have protection circuits , including DC leak.I think that's essential, as an amplifier fault can destroy tweeters and midrange drivers. Bass drivers can take more abuse, at least long enough for any fuses to blow in the power amps, (assuming there are some!) I use normal bipolar electrolytics for protection, as they should have very little voltage across them in normal use, so don't see the point of paying more for film caps.
I followed someone's suggestion years ago to unseat and reseat the ribbon cable pin connectors inside the box, as fpitas said, to get rid of the rice krispies. That simple fix worked for me and has continued to work ever since. The only unsolved issue is an occasional glitch in the hardware that causes a deep notch filter to get applied at about 5K. When that happens I just reset the digital signal going to the box and it fixes itself.What is RTV?
I have a unit that exhibits the rice krispies effect in one channel. I only use one of its channels, so I swapped the cables to the other channel. I've been too lazy to open it up and correct the problem, but I will soon.
