Buckeye 3 Channel Purifi Amp Review
Rate this amplifier:
    Votes: 19 6.9%
    Votes: 66 24.1%
    Votes: 151 55.1%
    Votes: 38 13.9%
EJ3
James Island, SC
I have to admit tough that the »WAF » descriptor always sounded a bit sexist to me. As if men can’t appreciate great design.
I will say the, while many men (me included) do appreciate good design, that, for what I would consider 'nice enough', every women that I dated before I got married at 48 years of age (and my wife today) have felt that (whatever it is): it could could be nicer, more aesthetic, more integrated, etc.
And I agree, because it is true in my mind also with the caveat: as long as it does not take away from the function. So, in my mind, the statement WAF simply correlates with my experience.
It seems that is true in my life, even with a women who keeps a dead 7 ft snake (the snake varies but there usually is one [that she herself killed & zip ties onto the gate]) because (according to her) it keeps the amount of company and solicitors down.
I inquired with her about the aesthetics of this and she said: "Not to worry, it is pure function and it's aesthetics are its function." I had to agree, as I could not think of anything else to say about it. She is now in her late 50's & still keeps a snake on the gate.
The first time my wife came with me to visit this friend of mine, my wife inquired to me about the snake on the gate, I explained it and my wife simply said "Makes sense".
Buckeye Amps
Not to delve too far off topic and create a social "discussion", but I think it is more to do with the target audience and less to do because of any aesthetic taste difference between genders.
What I mean is my GF is super into audio/music (she knew who Trinnov was) and has no issues with how things look as long as they perform.
Most of my guy friends are not into home theater sound and will always comment on how amazing a $300 cable looks, etc.
The term WAF usually works well because a majority of this hobby is male dominated. But as pointed out (and I agree) it is not a one size fits all acronym.
pma
Prague
Nothing said here can be taken as an excuse for the bent top cover of this amplifier. This is not about WAF or aesthetics, this is about amateurish work and lack of respect to customers.
Matias
São Paulo, Brazil
We should all be thankful for the internet warriors saving our poor souls from such perils.
Rick Sykora
Stow, Ohio USA
Moderators please note that Pavel's account may have been hijacked by the grinch! :D
Since Dylan has clearly shown great respect for his customers, that should not require any further consideration imo. If anything, he has been very clear about the case aesthetics. They are not my favorite, but I do have 4. 2 older ones (I bought from him) and 2 of this newer style. The 2 of this style are 2 channel ones and the fit is as good as it gets for this style of case. There is no bend or major gap to be seen. This leads me to suggest some other more likely causes:
  1. It may be that the wider 3-channel case has a bit more of a gap...
  2. It may be that the case was opened and did not get put back optimally...
  3. It may be worsened in Amir's picture than it really may be too.
In any case, the 3rd one is illusion and the first 2 may be readily improved by reseating the case and/or adding some gasketing tape. :cool:
amper42
The Buckeye case is an absolute non-issue. I have four Buckeye amps. I don't buy audio gear to look at. I listen to it instead and it typically hides in a shelf. PMA probably would miss out on the awesome value/features of an RPi4 too - just because it's ugly. Beauty is in the eye of the beholder. If it sounds great, I don't care what it looks like - and the Buckeye amps look better than lots of other stuff in most peoples home. Form over function? I don't think so. To each his own.
fatoldgit
Putting aside the current technical issue (and whatever lessons learned re more robust pre-production testing that Dylan can take from this) maybe the other lesson is he needs to step away from the pure technical side and cast an eye onto things like fit and finish.
Sure a minor panel gap might not matter to him but to some people it might say "if the guy who made this is happy enough (or in others minds, sloppy enough) to not worry about a panel gap, what else, more critical did he skip over"
For the sake of a screw or two, the panel gap issue would be non existent.
As a retired software guy, you might have the best software product in a specific category but if the UI design/implementation is poor you will lose customers for the same reasons - if the UI is crap, what else is.
Dylan states he uses custom made cases... I suggest he work with his supplier to sort this panel gap issue out for current and future products.
Peter
Bachemar
I have the 3 channel Purifi, and there’s no gap on my unit. I suspect Amir’s unit may have been opened at some point and not been reseated properly.
If I press the top edge in the middle of the case, there is about 0.5mm of give. A clip on the inside to hold the top to the front plate could easily solve this without a screw to ruin the look.
My biggest recommendation to Dylan - would be to use countersunk screws for the side panels, or even better - have the panels wrap to the bottom, so screws are the bottom plate, with similar clips to hold sides to the front panel.
PC cases do this all the time (except they’re usually screwed to the back instead of bottom)
Sokel
It's time for your most superficial member to write (I have stated it a lot of times,I can't help it!)
Do I love this case?Absolutely not.
Is it practical?No,dust will have a party after some time.
"Yeah" (sic),you like fancy stuff,etc,blah,blah,blah" :
Nope,I don't like this LESS than I don't like that wooden peachtree.
And I love the audiophonics one!
"Yeah (sic²) but it would raise the cost" :
I'm not really sure,anyone that makes diy knows that a nice case from Modushop as example that fits 3 purifi costs 150 euro tops,including the holes and at least has perfect fit.
Common sense,nothing more.I'm sure Dylan (which I really like,his responses are an oasis of politeness in a "yeah" desert) can make a good deal for a nicer case.
Buckeye Amps
If I press the top edge in the middle of the case, there is about 0.5mm of give. A screw could help, that would also ruin the look of the top, so maybe a clip on the inside to hold it to the front plate.
My biggest recommendation to Dylan - would be to use countersunk screws for the side panels, or even better - have the panels wrap to the bottom, so screws are the bottom plate, with similar clips so the sides hold the front panel.
The gap occurs if the top panel screws are to tight upon reassembly. Easy remedy. Just didn't know it would become such a focal point of discussion. But there is the fix in case anyone wants to infer "that other problems might exist from my sloppiness"
Buckeye Amps
@Bachemar
The countersunk screws is an update I am considering. But it does bring a cost increase (not huge) and I'd have to change the thickness of the aluminum.
Buckeye Amps
On the topic of something more appreciable (performance):
Still running through testing, have excluded quite a bit of possibilities as to what is causing the distortion.
Buckeye Amps
Even with a 1:1 Euro rate, this would still add cost to the amp. I'm also not sure if Modshop does customization such as adding stand offs for PCB mounting, different powder coat and anodized options, large MOQ's, Free Shipping. And a few other things the manufacturer I use offers.
fatoldgit
I wasnt making that statement specifically about you (i.e. you were sloppy) but we have a continuum of viewpoints from people:
1- people who dont notice the minor gap cause they arent wired like that
2- people who notice it but its not an issue cause they care mainly about the tech aspects of the product
3- people who notice it and its a concern because it casts doubt on other aspects and even if the tech aspects are all ok, they still wouldnt buy the product cause there will always be other products that measure as well that meet their design aesthetics.
For example, in my case (no pun intended) I would never buy a Mcintosh audio product cause I cant stand the looks.
And re the counter sunk screws... I actually came back to make that comment... you might not think its an issue (from your purely engineering perspective) but to some potential customers the lack of them means they might look else where because aesthetics is important to them.
Peter
Bachemar
To be clear, I was saying my case does NOT have a gap. So any gap on Amir’s unit is not indicative of other units (yes I know, sample size of 2). The rest of the case actually feels quite solidly firm (except for the one point at the top, front center)
fatoldgit
Well.... that top panel will have a sympathetic resonance and I have seen (not gear I own) panels such as this resonate to the point of being audible.
Again I am not being critical but for a few cents here, a few cents there you can remove any visual issues... you might not think its critical but many people (maybe more than you can imagine) consider looks as important as any other aspect of a product.
Peter
Sokel
That was just an example and for 1 case as a hobbyist,there are other places too.
I think it does all that and more and a costumer who makes lots of cases can get a nicer deal.
(The 150 euro case I had in mind is one with heatsinks and all,simple ones cost less).
I don't want to appear like I advertise them though I'm only a happy costumer who has got 3-4 cases (one of them is 10yo and still running nice looking!).
Buckeye Amps
As always, I appreciate all the feedback but the case design is definitely not changing, except maybe for adding countersunk screws.
From day one I've said if someone looks at my cases and says "not for me" regardless of price vs. performance, than my product is not for them.
If someone infers that a gap in the cover (which I've already said is easily addressed) means my overall workmanship is questionable, there is plenty of evidence to suggest otherwise.
