Burson Soloist 3XP Review (Headphone Amp)
Rate this headphone amplifier:
    Votes: 155 64.6%
    Votes: 66 27.5%
  • 3. Fine (happy panther
    Votes: 5 2.1%
    Votes: 14 5.8%
BrokenEnglishGuy
Added measurements for the fixed gain mode to the review. It definitely cleans up its response. Here is the dashboard for example:
See the review for the rest of the tests.
Good for a very high power headphone amp.
This headphone amp is good for planar magnetics headphones, like hifiman susvara, some dan clark Audeze, etc. Not for IEMS ;)
With planars 90dB that sinad is almost inaudible.
edahl
I wouldn't be surprised if it literally destroyed all planars at max volume. I've already heard one such case with the HE6se
BrokenEnglishGuy
Planars don't die that easily, some planars hit 104dB less than 0.5% THD, like my EFO.
I guess is more probably a headphone with DD going to destroyed.
pseudoid
I was actually saving up money for a Soloist 3XP.
Let's just say I'm probably going to spend a lot less on a topping A90D in the near future, And will invest the difference into something else.
Yes. Take the money and spent it on better speakers, room EQ or headphones... much better invested and more likely to make an audible difference. ;)
Oh Boy! Oh Boy!
I am sure that the PinkPanthers would welcome you sharing some of your $aving$, with the rest of the claw.;)
AudioSceptic
Northampton, UK
For neither. It's a great piece to play with, change things, and maybe try to overcome it's horrible test specs. There's peeps/enthusiasts that dig this sort of cult status or whatever this gear has and they dig changing things for what they imagine are the better. I made a conscious decision a few months ago to not hassle OP amp rollers and MOD'ers because they are just into that scheme of things and for many this is their way of getting educated in electronics. So I don't see the Burson tested here as being a throw away. It has uses for some people and some of those OP amp rolling peeps are here at ASR I think going from what I've read. As this unit has lethal to headphones output power capability I imagine for some peeps that makes it better/more exciting for them and the amp is then held to a higher regard. I don't think forcing OP amp rollers into the closets is a goal. They should be able to come forth and request help with stuff so they can self educate.
If this thing cost a couple of hundred, then you might have a point, but what sane person would pay >$1000 for something that's broken, just to play with it in the hope of improving it? What could anyone learn from this anyway? Wouldn't they be better off learning some proper design and then building their own?
PeteL
Learning to be a good electronic designer can take decades, and yes this process of studying the behaviour in OP amps can be part of this. Among many other experiments, you don't go and read an electronic for Dummies book and design a great amp.
Doodski
I think you hold these people to a higher standard then even they are looking to achieve. Some people just want to tinker and not get into electron principles and fundamentals at the formal level.
Ra1zel
Poland
Arguably doing a headphone amp based on op amps is as easy as it gets.
Try discrete and retain good performance without cranking 130dB open loop gain, now that's skill.
LTig
Europe
I agree, but 130 dB open loop gain of op amps is usually below 20 Hz and falls 20 dB / decade above.
Phoney
I
Indeed, my wish I knew up front was a pipe-dream. The alarming part is that the folks who shell out big bucks for these “luxurious” mediocre products insist that they sound better than fairly-priced equivalents that outperform them, and over at Head-Fi they’re speaking authoritatively about this as they encourage others to fall for the same shill. Which not only reinforces the price points but perpetuates the quality myth these “luxury” brands enjoy.
I always marvel when people refer to ASR and Head-Fi as two equal resources that simply differ on “opinion”—and sadly Head-Fi is the far more popular for reasons their denizens don’t understand—it’s corporate-funded and completely infiltrated by industry plants perpetuating the myths. Head-Fi is one big marketing cesspool where folks think they’re getting useful information because they think they’re getting unbiased advice from peers. They don’t realize that their peers are passing along the promises made by one sheets created by manufacturers, who are not bound by truth in advertising laws…
ASR and Head-Fi has about the same amount of viewership for the last 6-12 months.
PeteL
Baby steps, 99% of the population don't even know what an op amp is, nor a DC offset, nor what brings an op amp to oscillate. "easy as it get" for you maybe. If you have an engineering degree and studied audio circuits. and have some experience. You may not have anything to learn about opamps designs but others do and it can be of interest.
SirYabadaba
True. The DC offset is the thing that scares me the most about accidentally damaging my headphones but if this measures so poorly yet there is no audible distortion present, why does that end up mattering?
As the owner of this particular Burson Soloist, I can tell you.
Yes, I am at times terrified of this amp. I once sent 28 volts down the right driver of my HD 6XX! Made a large bang. I swore the driver must be dead. But no, still works perfectly fine.
The same 6XX that has survived being flung over the handlebars of my bike along with me twice, yet they still work.
SirYabadaba
It sounds good. Just a high noise floor. Nothing wrong otherwise really. Someone mentioned its kind of like a tube amp and that actually seems to fit my experience too.
This is how I see it. I thought I would like the sound of tubes as they were described to sound, and at the time I bought it, I was listening to music so often and for so long, I would have an amp running all the time, and I knew it would get expensive if I did that with actual tubes.
Edit: Except the DC offset issues. Allowing any headphone amp, regardless of price, to have such a level of offset is ridiculous and poor design.
SirYabadaba
If you want something that sounds similar, yet measures much better, I know people compare the Burson Soloist to sounding like the Singer SA-1.
And that one you don't have to worry about DC offset blowing up your headphones, unless you modify the amp.
Snoopy
Got already a SA-1. But need another amp for another room
