Class A “class D killer” amplifier with THD less than -120dB
Status
Not open for further replies.
mhardy6647
The schematic I see in post #103 is full complementary. PNP and NPN output devices.
Oops, I missed the schematic! Derp.
Sorry.
Does it ”you a toe-tapping experience that other solid state amplifiers do not”?
Toe tapping would be quantifiable, no?
Rate and pressure, at the least. I would think that a rhythmic parameter, somewhat analogous to jitter, could be measured as well. Not sure if the figure of merit would measure syncopation or arrhythmia. though.
:cool:
Chrispy
PNW
Speaking for myself and a few others here, us horn guys don't need more than about 5W on peaks. But we need an amp that is very clean at low power. My horns draw 20mW average at my loudest listening level.
How many amps does that actually translate into a "problem" with? I guess a 5W room heater would be okay, tho :)
fpitas
Northern Virginia, USA
Class AB often has residual crossover distortion, seen at higher frequencies and very low power outputs. There's a good reason Benchmark installed a feed-forward auxiliary amp stage.
fpitas
Chrispy
PNW
With a horn? Yes. You're certainly using a normal amp in a way the manufacturer never intended.
Just how sensitive are those horns? So what did you use that was audible and what do you use now?
fpitas
The TAD driver is 111dB/W:
Or about 20 - 25dB more sensitive than your normal cone driver. I tried a few other amps 11 years ago when I started playing, but the "right" way, pretty much standard for recording studio design, was to use class A. These days I could use the Benchmark AB, or class D.
LKA
I would like to present my "Class-D killers" here. They have low power consumption and low distortion, hence the naming.
LKA
H-ENG (Homeless Engineer)
100W/4R, Class B, single supply, CFA retro amp
LKA
LeXaN
170W/4R, Class B, current driven, CFA amp
LKA
LeXaN Buffer
170W/4R, Class B+G, current driven, power buffer
Blumlein 88
What is with wanting to kill class D amps?
Class D amps are powerful, efficient, inexpensive and provide excellent performance making them THE VALUE proposition among amplifiers. Yet everyone wants an alternative. Makes no sense.
LKA
I hate them ;) I am ancient
IMHO, Class B+G is better than Class-D in terms of efficiency, distortion, etc
voodooless
Netherlands
I hate them ;)
Can you back that up? Distortion-wise, we can already see what's going on. Efficiency-wise though would be nice to have a comparison.
DSJR
Suffolk Coastal, UK
Just do what you do, make 'em reliable and abuse-tough (as my fifty year old US made prosumer power amps are and still with half-decent performance today, albeit with deliberate limitimg into 4 ohms and below) and dress 'em nice, hopefully at not too silly a price and I'm sure you'll have a market for them.
restorer-john
Class D love quoting efficiency numbers at full power. Who cares about efficiency at full power?
Seriously, if you are cranking it near full power, nobody gives a chit about being green and saving the planet, do they? They are partying hard.
I'm more interested in efficiency at low powers. The levels most people listen to music, most of the time. And a class AB amp hardly pulls much at all in that situation. I have small-medium power integrated amplifiers running barely over 10W idling along. Some might pull 20W.
Class D SMPS supplies pull more than that on their own. Class D 'efficiency' is a mirage.
Matias
São Paulo, Brazil
While that is true for class AB and I agree, class A amps are another matter. :)
digitalfrost
Palatinate, Germany
I measured only two integrated amps but they pulled 50W idle each. Also I think usage patterns may have changed. My amps run all day long. I don't turn on the amp in the evening and listen for 2-3hrs. I have them hooked up to the PC and I need audio to just work. Two amps because of Sat/Sub. So with the AB amps before, I wasted 100W most hours of the day just for the opportunity to have sound.
My class D amp is specced at 7W idle power consumption, but it also has auto/on off. For the sats I use AHB2 which only consumes 12W idle. Whish that one had auto-on as well...
restorer-john
Yes, totally. Scary low efficiency. Even that big Marantz I pictured above is the equivalent of a couple of outdoor medium floodlights in Class A. Or an entire house of LED lights...
Status
