Delta-sigma vs “Multibit”: what’s the big deal?
DonH56
Monument, CO
I saw that the dac can render muli level tones keeping very low thd. I wasn't sure of this seeing the other tests before. Yet i'm not sure of the precision of the level and how much it matters.
The DS design has greater resolution and lower distortion thus its levels are more precise than R2R DACs.
solderdude
The Neitherlands
The precision of the DAC in question has been documented and exceeds that of any known (to me) R2R
edit: DonH56 beat me to it.
solderdude
The Neitherlands
I suspect Alan's DAC1 but I may be wrong about that as well.:rolleyes:
Have a look at the linearity plots made by Amir of R2R and DS DAC's.
JJB70
Singapore
Delta what now? :facepalm:
Blumlein 88
I'm posting from a phone or I'd find it. If you'll look at some tests I've posted on low level linearity, you'll see sigma Delta DAC s are practically perfect down to 22 bits. Probably lower but it's hard to measure that low. I don't think any multi bit dacs come close.
The signal I use has 1 bit positive, a zero and 1 bit negative with a zero. The values are such that only one bit level is on at anytime and no others.
Does that make sense?
RayDunzl
Central Scrutinizer
Riverview FL
Is it for all frequencies?
Lower frequency will cause more bits (samples) to be used (populatd) per cycle.
This signal frequency would be at an integer ratio to the sample rate, I'm thinking 1/4 (but I get to be wrong).
Bluespower
Do you think it would be revelant to test how much bit precision at 16 khz we can get from 44.khz 16 bit sample?
Blumlein 88
Yes 1/4 of sample rate.
RayDunzl
Central Scrutinizer
Riverview FL
You can get more than 16bit precision from dithered 16bit input (I think, somebody else chime in please).
