Dynaudio X14 Speaker Review
Pearljam5000
Sorry if derailing a little, but I just noticed: is this a multiple entry horn mated to that compression driver? That'd be quite cool.
Unfortunately i don't know.
But Genelec is always cool anyways :)
andreasmaaan
According to Genelec, it is not. But I'm not sure what function those little vents or pads on the tweeter waveguide fulfil...
restorer-john
That's a bevel. Not a waveguide.
Any physical structure which directly affects the dispersion/propagation characteristics of the tweeter in a controlled manner, may be referred to as a waveguide. A so-called "acoustic lens" is also a form of waveguide (and tweeter protector).
And just because a waveguide doesn't have a flared/throated/horned or an ASR approved 3D CAD-looking assymetric design, doesn't mean it isn't intentional, carefully designed and does exactly what is required in terms of dispersion for the application.
Here's a few tweeters shots from some speakers lying around my loungeroom.
Where does your "bevel" end and a waveguide start?
Matias
São Paulo, Brazil
The ones you show look like they serve a meaningful purpose. The Dyn does not.
I know. Weird hill to die on.
It's your word against the word of the actual designers. My money would be on them.
jtwrace
Orlando, FL
Ericglo
The only downside is that it's very similarly looking to much cheaper models View attachment 94059
It was developed for the all conquering M2. JBL realized that they could use it in multiple models. And why wouldn't they? Why spend money designing a lesser performing waveguide?
It should be mentioned that Charles Sprinkle said that it may not be the optimum waveguide design. Of course, he may be biased as he had left JBL and went to work with Kali.
Ericglo
Interesting, do you have a link to more info on that?
I think it was in a reddit thread that Kali did. I remember looking to see if he would discuss the differences and he mentioned it. I don't believe he went into detail, but I can't recall. It may be in this one.
https://www.reddit.com/r/IAmA/comments/9ne8ce
https://www.mixonline.com/technolog...oped-m2-and-re-ignited-its-studio-line-383733
https://www.head-fi.org/threads/an-...-director-of-acoustics-for-kali-audio.918189/
Ericglo
It wasn't to far into that thread.
We are having a third party do those measurements, and will publish them on our website as soon as we have them.
The Image Control waveguide was designed to provide individual control of vertical and horizontal coverage and lower pattern control frequency. It was also constant directivity. The Kali waveguide has an elliptical waveguide with a sound power that drops at about 1dB per octave. This creates less of an inflection in the soundpower than a constant directivity waveguide and in our opinion sounds more neutral. By controlling the spacing of the transducers and vertical pattern, we were able to optimize system integration.
level 2
80a218c2840a890f02ff
1 point·2 years ago
Thanks for the detailed reply. I've wondered what the "ideal" sound power curve might be for some time. My own speakers are basically constant directivity (the sound power falls ~1dB between 1.9kHz (the crossover frequency) and 10kHz).
level 3
Kali_Audio_Official
1 point·2 years ago
The woofer has a soundpower that is esentially the same as the on-axis response at low frequencies. It falls off at higher frequencies as the system becomes more directional. If the HF is constant directivity, this puts an inflection in the soundpower at the crossover point. Both HF and LF could have a smooth response, but there is still an inflection. This can affect perceived timbre. By having a controlled directivity waveguide with a small soundpower slope, we can minimixe the inflection in the sound power and in-room response.
Ericglo
Another quote.
The Image Control waveguide on the M2s actually had defined coverage and smooth response in the oblique planes. Because the waveguide needs an expanding cross sectional area, the "knuckles" were used on the horizontal and vertical planes to move the upper pattern control frequency higher, but the obliques could not. as a result, the upper pattern control frequency in the oblique planes was significantly lower. this could potentially affect perceived timbre. The solution, of course, would be to have a compression driver with a 1" exit, at the expense of higher distortion from the non-linearity of air at higher SPL.
A well designed diffraction waveguide should not impart sonic coloration if the diffraction feature is blended to smear the reflection in time. This actually reduces the reflection back down the throat and associated frequency response (and impulse response) anomalies.
level 2
ilkless
1 point·2 years ago
Thank you for the excellent answers!
diffraction feature is blended to smear the reflection in time​
So this smearing isn't something that we can perceive?
level 3
Kali_Audio_Official
4 points·2 years ago
From Charles:
I'm not aware of any controlled experiments with subjective analysis on this. From my own experience, I have not been able to hear artifacts from blended diffraction features so long as the impulse response and frequency response are good.
neph
Οverall, the X14 measures pretty well:
X14 Frequency response: +/-2.5dB 80Hz-20kHz
M105 " " : +/-2.8dB 80Hz-20kHz
Regarding the waveguide thing:
ATC also refers to its new tweeter as "short throat waveguide"
http://www.acousticfrontiers.com/atc-speakers-technology/
Judging by the comments, have we reached a point that a waveguide is a "must-have" for superior directivity thus sound quality?
If yes, why don't more big OEMs use them?
Also even the best dome+shallow waveguide combos fall way short to the pattern control abilities of a good horn+ modern compression driver combo.
Considering a)the ease that the compression driver's response can be linearised,b)the considerably higher headroom and c)ignoring aesthetics, the latter combo guarantees higher performance versus the former. Or doesn't?
