Welcome to ASR! Thanks for sharing your experience with the speakers even though this thread mustn't have been the easiest to jump in to.View attachment 243749Hi!
This are my first post. I have been a lurker for quite sometime and I felt that I wanted to share my experience with these loudspeakers since they measure so poorly in every review that I have seen.
I was able to borrow these from a hifi store for a week to try these at home.
I used a Umik-1 and REW to make these measurements. They are measured in room, about 3,5 m on axis.
The cyan line is with subs, the purple without subs and the brown is without subs but still with the 80hz crossover.
The over all experience with these are quite good actually. I feel that they would need a little lift in the lower tremble tough to balance it out sound wise. They sounded quite dark with a bit of sparkle up in the higher tremble region.
They are definitely not made to be sitting to close to, since they measure more poorly the closer you get.
I hope this helps to sparkle more discussion
Kind regards
The 6k on-axis dip seems to fill in quite a bit once off-axis. This shows up in your in-room measurements and also in the Hi-Fi Voice test.
I'm sure they sound much better in-room than the on-axis measurements would lead to believe. Have you tried experimenting with EQ if filling in some of the 5-7000Hz area would make an improvement?
