Fosi Audio HD-A1 Budget Amplifier Review
This is a review and detailed measurements of the Fosi Audio HD-A1 amplifier. It costs US $200 on Amazon including Prime shipping. It was kindly sent to me for testing by member @IowAudio. He has a review of it on youtube.
The front is not bad for a budget product:
The font could use some help but you don't listen to that. Nice to have a volume control as many budget amps don't have one.
The back panel connectors are unusually high quality:
Fosi Audio HD-A1 Hi-fi Power Amplifier Back Panel Input Binding Posts Audio Review.jpg
Oddly the power switch is on the left (right above).
There are no safety or regulatory certifications which is always a concern for mains operated product.
In use the unit was quite robust, never shutting down or getting overly warm.
Company advertises that the topology is similar to Marantz's HDAM amplifier stage. Whether that is the case or not, I have not tried to investigate:
The amplifier is Class AB and uses a toroidal transformer which makes it quite heavy and sturdy for its size.
Amplifier Audio Measurements
As usual we test for noise and distortion by asking the amplifier to produce 5 watts into 4 ohm load using a 1 kHz signal:
This is not good. We have tons of power supply related spikes (left of our 1 kHz tone) and harmonic distortion after our tone. I suspect this is a low feedback design and as such, is not very linear. No wonder then that the ranking amount all the amplifiers tested is almost at the bottom:
There is some talk about it being tube like so maybe that is the excuse for poor performance.
Noise performance is not great either:
Frequency response and crosstalk on the other hand are very good:
Fosi Audio HD-A1 Hi-fi Power Amplifier Frequency Response Audio Measurements.png
But our 32-tone signal resembling "music" is not:
Power into 4 ohm load does not meet spec:
Fosi Audio HD-A1 Hi-fi Power Amplifier Power into 4 ohm Audio Measurements.png
It gets closer though if we allow more distortion:
Fosi Audio HD-A1 Hi-fi Power Amplifier Max and Burst Power into 4 ohm Audio Measurements.png
Naturally power drops with 8 ohm load:
Fosi Audio HD-A1 Hi-fi Power Amplifier Power into 8 ohm Audio Measurements.png
The Fosi HD-A1 amplifier promises more from its looks and weight than it delivers in transparency. Then again there is some pretension of tube line sound and such so maybe this is intentional. The high distortion and noise don't do much for me so it is not something I can recommend. But I didn't want to give it the lowest score because I don't know if there is anything better in this power range and price.
The panthers have heard that Covid virus doesn't hurt them much so they want to throw a summer party. I have saved up enough money from donations to buy them steaks to eat. But need to get a hazmat suit for me so I don't catch the virus and for that, I need money, and lots of it! So please donate generously using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
By the way, the above is the 100th amplifier I have reviewed! Can you believe it? It seems it was just yesterday that I was happy to just be testing lightweight desktop products. I wanted to thank all the people who have sent these in for testing but my aching back doesn't allow it. :)
$80 more gets you a Denon S540 5.1 receiver, would be interesting to see how that compared to this 2ch analog amp.
AVRs are huge though so I don't see them being a proper replacement for these amplifiers where you want to stick a piece of furniture and have some music.
daftcombo
Hi Amir! Thanks for the review. I'm very happy to read reviews of budget amplifiers like that because I think a lot of us are still on the quest to a golden little amp.
Now that you have a lot of speakers at your disposal, will you consider doing a subjective listening of those amps?
I was hoping to do that but I am getting so hammered to test gear that I just don't have the time at the moment. There are so many boxes in our entry way that no matter how fast I ship them out, more arrives to fill them. My wife is tripping over them which is not good either.
Cahudson42
Or a stereo Yamaha RS202 for $149..
https://www.crutchfield.com/p_022RS202/Yamaha-R-S202.html
And yes, both of these are 'full size' compared to this Fosi. But for that you likely get much better ventilation and unit life. Personally, I can always seem to find room somewhere, even my BR system with R162s and vintage RX-396. But I also don't worry at all about WAF..:)
Vini darko
Dorset England
Happy 100th amplifier-day
zepplock
San Jose, CA
I'll take that yamaha over many other budget amps.
Willem
I will happily argue with friends that good audio does not need to cost a fortune, but there is also a sensible minimum below which you no longer get value for your money. In my view with integrated amps this sensible minimum is reached with the 2x85 watt Yamaha AS 501. You get tone and balance control, loudness, plus mm phono and digital, and excellent measurements. Here in Europe it costs about 350 euros.
MZKM
Land O’ Lakes, FL
I forgot the Topping MX3 exists at just $130, though is slightly less powerful but is an integrated amp. The Topping PA3 is $105 and would be a direct competitor to this Fosi amp, as is the SMSL SA98E.
SpaceMonkey
Yamaha a-s201/301/501, cheaper pioneer, onkyo, teac, denon. Lots of options, albeit large size. Well sometimes you've got to crack a few eggs to make an omelette.
Feanor
southwestern Ontario
Sorry, Amir. I admire your efforts but what I'm getting weary of is endless reviews of tinny desktop equipment. Who really cares?
I want more reviews of substantial 'main system' components like Purifi amps and, yes, the Parasound preamp.
SpaceMonkey
Amir is limited to what people send him. Seeing how economy is performing it is unlikely we'll see any hardcore stuff.
Willem
I admire Amir's efforts, but given that he is already stretched reducing the number of tiny boxes may not be a bad idea. The question remains whether people will send him the heavy boxes. But I agree, those would be at least as interesting, and are sometimes underepresented.
MerlinGS
I Yamaha AS 501. You get tone and balance control, loudness, plus mm phono and digital, and excellent measurements.
Do you have a link for it being tested?
