Fosi Audio TB10D Amplifier Review
Rate this amplifier:
    Votes: 18 6.9%
    Votes: 75 29.0%
    Votes: 136 52.5%
    Votes: 30 11.6%
mctron
Hi All,
I have a single rear speaker presently powered by a Dayton APA150. I am going to order one of these FOSI's and compare. Was encouraged by my wife to try it based on the much smaller size. This single rear is in our living room behind the couches and anything that hides some electronics is favorable to her. So who am I to argue in trying new gear out especially when it can be returned to amazon. Got it for $59 plus tax after coupon.
Anyone have an opinion on what I will expect with this vs a bridged APA150?
Thanks
It will functionally be the same but be smaller and use less power
Mustang
Well, overall the Fosi was ok but the noise floor was much worse than the Dayton APA150. I think the power supply on the Dayton might be superior. There is a hiss from the tweeter on both that's probably acceptable but the woofer was making a hum from the Fosi that isn't there on the Dayton that was unacceptable and the reason I'm returning it. Not sure if I got a dud and it's worth trying another or I might just stick with the Dayton.
A bit dissapointing. Any recommendations are welcome.
kiwipaul
Bypassing the tone controls
Greetings. I have a Fosi Audio TB10D on order. I secured it for a good price but I want to have the option of bypassing the tone controls.
It seems to me I could replace one of the tone control potentiometer to add one with a built in switch, then use something like this audio relay to bypass the tone controls.
Any thoughts?
Aliexpress - Ultra-small Double Pole Double Throw Polarity Relay Module Mini
On reflection, what might be better is to use the switch on the potentiometer as the power switch, and adapt the existing power toggle to enable the tone defeat...
Kimbrough Xu
Any thoughts?
Seems like you don't need the tone controls?
Why not just got the Fosi Audio V3 https://www.fosiaudio.com/product/2-channel-amplifier/v3/?
Fosi Audio
Any thoughts?
Do you mean you want the tone controls but also want the bypass function?
Can you let me know why?
Talisman
Milano Italy
this is simple. Tone controls may be useful in certain situations, but when they are not needed any audiophile wishes they could bypass those circuits.
Almost all historical amp brands have implemented the "direct" button which bypasses the tone control circuits, I'm surprised you don't know about it @Fosi Audio
restorer-john
Amplifiers and preamplifiers have had tone controls and bypass switches for 50 years.
Flatter response, better noise and lower distortion when bypassed and useful control when in circuit.
Doodski
Flatter response, better noise and lower distortion when bypassed and useful control when in cicuit.
Yes... it sounds wayyy better with tone controls... :D
Doodski
This commentary brings up a intriguing question. How much would it cost at wholesale cost and retail cost to add a couple of op amps, maybe buffers and pots to make tone controls?
restorer-john
Schiit make a standalone tone control IIRC.
At the peak of the cost cutting in the 80s, tone controls were put in the NFB loop of the power amp stages for many of the big brands to keep costs down at the low end. Not my idea of superior design, but it worked. Basically someone said, why build a standalone Baxandall feedback active tone control up front of the power stage when we already have the guts of of it already?
This is actually a PM-640 HK integrated from about 1983/4. An otherwise very nice amplifier.
Fosi Audio
Yes, I know.
I just confused if one wants the tone controls, why bypass them. That's why we have TB series (TB10A, TB10D) and V series (V1.0, V3) .
Doodski
That's very sneaky design work on the HK schematic. I like it. Are there advantages or disadvantages for performance using this method? :D Wonderful nice dark schematic.
kiwipaul
Yes, I know.
It is preferable to have both so you have the option of using the tone controls, or bypassing them. Amplifiers sometimes have relays to bypass the tone section of a preamp stage.
Something like this would work.
OpticonPrime
Netherlands
@Fosi Audio
What is the powerconsumption in standby?
And a feature request: make a on/off/auto switch function.
I am looking for a "light" (4 Dayton Puck mini) basshaker amp is Fosi the way to go?
Kimbrough Xu
Auto is a great idea. My partsexpress Sub amp has Auto. When it detects an audio signal, it turns on. After X seconds of no audio, it goes back to standby.
Doesnt it consume too much power when standby?
GrayA
Not sure, the manual says "When the power switch is in the auto on position, the amplifier will automatically turn
on when a signal is present. Note: In auto on/off mode, the Power On LED is always
on, even when the amp is in rest mode (off)."
