Fosi Audio TB10D Amplifier Review
Rate this amplifier:
    Votes: 18 6.9%
    Votes: 75 29.0%
    Votes: 136 52.5%
    Votes: 30 11.6%
gasolin75
Denmark
Just remember like klipsch the sensitivity might not be as high as rated
96 db is 106db with 10 watt and peak 116db with 100 watt using klipsch rp-600m, that is alot, add 6 db peak power we are above 120db
gasolin75
Denmark
"why would they make a mono version"
To have more power for cheap (around $150 for two). I already have decent power supplies and just want to get enough juice to power speakers. And I'm confident, there will be left over because of the bad review it gets from Youtube.
The TB10D is perfect for me if it has an option (a toggle or slider switch) to select stereo or mono. I may buy two if they offer the DIY kit version for say =,<$60 dollars each. The NAD C268 is $1,000 a unit, and as a newcomer to sound, I did not want to indulge and spend over $2k in an audio amplifier.
Mono the chips got not much more power, stereo gives you more spl then mono https://www.audiosciencereview.com/...3255-amplifier-with-mono-stereo-output.48226/
2023-11-12 10_41_01-Aiyima A07 Max - Aiyima's new TPA3255 amplifier with mono_stereo output _ ...png
gasolin75
Denmark
2x100 watt and 2 speaker is more power then one of the same speaker and 1x200 watt
gasolin75
Denmark
Change opamps is that possible and which one ?
I wanna im prove the highs, softer more airy,less loud
Juampa1989
@Fosi Audio Hello Fosi, have you seen the possibility of launching an amplifier similar to this one also with tone control, but adding optical input and remote control?
Kimbrough Xu
Others don't understand why replace a useful thing with a useless one. Choose your poison
Oh, got it.
But if you add tone control to this amplifier as well as the remote control, then it is not convenient to control the Treble and Bass with remote control.
I mean you can not know how much you adjust the Treble and Bass. With remote control, you need to an encoder to adjust the Treble and Bass but not the potentiometer.
But with a display, you can look at the screen.
Ashoka
Shipping a 32V 5A power supply while advertising 2x300W output is what is called ‘caught with pants down your ankles’. In more clear language; a blatant lie.
works best with lower power supply, with higher power supply may not last a year. Just over hyped ad.
