Fun with vinyl measurements
Balle Clorin
Balle Clorin
Balle Clorin
Balle Clorin
I found another quite easy way of checking cartridge response by REW.
1. Parks Audio Puffin set to Phono EQ=500R-0
2. Record JVC TRS1007/Clearaudio TRS1007 frequency test record/Bruel&Kjær QR2010 frequency sweep- All of these have RIAA EQ below 1000 Hz and no -RIAA constant velocity above 1000 Hz . The result a sloped reponse by -10dB&decade. I use CoolEditPro/AdobeAudition or Audacity or any other recording software to make a wav file
3. Import Wav file to REW without any calibration correction
4. Make a REW calibration file in Notepad with +20db at 2.4Hz and -20 at 24000 or some other -10dB/decade slope.
5. Select "Change Cal" in REW and apply the calibration file
6. apply some smooting on the curve
TADA!! you have your cartridge reponse
Balle Clorin
Balle Clorin
Comparison of different test records for cartridge frequency response. Note Clearaudio TRS1007 is supposed to be a replication of JVC TRS1007
Thomas_A
Sweden
Could you overlay the Clearaudio with the Elipson with 1000 Hz at 0 dB, at a 40 dB scale axis to see the fine deviations? Cartridge is?
Balle Clorin
Balle Clorin
Michell Gyro SE. SME V AudioTechnica OC 9ML/II. 12 years old New in Box, used <10 hours
RIAA stage Parks Audio Puffin
Thomas_A
Sweden
Balle Clorin
Balle Clorin
Se the review of Parks Audio Puffin on ASR , it is very accurate.
https://www.audiosciencereview.com/...o-puffin-review-phono-stage.19795/post-650281
The Cambridge TRS1007 is equalized by Puffin 500R-0 setting ( low frequency RIAAonly , no eq above 1000hz) and Both plots are transformed with +10db/decAde to plot horisontaly in a FFT plot. Elison has full RIAA eq
Clearaudio TRS1007, seems like IT has constant velocity above 1khz, same as my B&K QR 2010
Thomas_A
Sweden
Ok thanks,
If I measure using the white noise (or sweep) I get +0,4 dB and -1 dB response using my Shure V15Vx with JICO SAS (except for resonance peaking 10-20 kHz), same for fixed frequencies using the Elipson test record and the fixed frequencies from the Ultimate LP test record.I know from many other measurements (vinyl asylum, using Denon test records) that the Shure V15Vx always have measured with a slight sloping down. This is also what I find. The SAS stylus however, peaks with a resonance 10-20 kHz, unlike the original stylus:
The original Shure V15VxMR (not JICO SAS) from John Elison:
gi.mpl
He measured also the ATOC9MLII using the same test record:
gi.mpl
So the measurements agree quite well. I also measured my Ortofon OM40 and this one is more or less perfectly linear. I could redo that measurement with Elipson sweep just to check, but changing cartridge of my arm is a bit tedious.
Balle Clorin
Balle Clorin
Speed variations with old original belt. Michell Gyro SE
New alternative belt (nitrile) , with some good reveiws, not from Michell. Crazy speed variations..Belts are not the same....
Thomas_A
Sweden
Thanks for the instructions. I have just one question which I don't manage to fix and that is to "change calibration file". Should I import it as .txt in the frequency response option? I don't see where you change calibration file unless you do a measurement in the preference menu.
Thomas_A
Sweden
I got it now!
Thomas_A
Sweden
These are some old measurements of the V15Vx with boron stylus (lower curve), the NeoSAS ruby (upper curve) using 130 pF and 47 kOhm. The middle curve is neoSAS with 130 pF and 27 kOhm.
This is using a pink noise track. I have to redo measurements with a sweep to get a bit more reliable results, but the picture tells the principle.
JP
Brookfield, CT
130pF super low for a V. Is Vx that different?
Thomas_A
Sweden
Shure had 250 pF/47 kOhm as recommended for the V15V-MR as well as the V15VxMR. The Vx variant was a cheaper and less advanced model (non-laminated cores, inductance raised to 425 mH from 330 of the V15V-MR). For the V-MR Shure noted a range of 100 pF-400 pF with "negligible change" from the recommended 250 pF.
Thomas_A
Sweden
How do you make the polar plots?
Just FYI, my memory was indeed weak regarding the old polar plots and FM/AM demodulation. I found the old rec.audio.tech thread back in 2004, 17 years ago, and it was in a discussion involving other persons/nicks (Goofball_, Arny Krueger, Carl Valle and others), that discussed such analysis for LP12, a direct drive, and also my Linn Axis using a special software. I think I confused the name "Valle" with you nick. Sorry for that.
https://groups.google.com/g/rec.audio.tech/c/qGPRyrZVITA
Balle Clorin
Balle Clorin
Yes it agrees with my strobedisk from Project and quartz strobe lamp from KAB
