Fun with vinyl measurements
dlaloum
But the Bang & Olufsen MMC 6000 uses a comparatively long (x? mm) beryllium cantilever (I can’t find many good photos of this and, unfortunately, the diamond tip is missing on this specimen):
And a calibration plot for a typical production unit shows exemplary response to 40K:
Once again, success comes from the synergy of the complete system rather than the advanced strength of an individual design feature.
Would need to check - but there is no way a solid rod cantilever would achieve that - I would bet that this one is a beryllium tube...
With that type of cantilever Technics achieved the lowest ever tip mass... (although theirs was a tapered boron tube) and assuming a Beryllium tube cantilever here - the cantilever resonance would most likely be up at well over 30Khz - and from that calibration plot - it looks like it is around 40Khz
If your cantilever is intact - this one is definitely worth while sending for a retip - to someone who does "Real" retipping... ie: put a new rock on the end of the old cantilever - don't send it to someone who replaces the old cantilevers - none of the current solid rod cantilevers will match this - regardless of the material used.
The Technics EPC100 & EPC205, as well as the Shure V15VMR and a number of others used full length beryllium / boron cantilevers to achieve these kinds of results.... - but these were all tubes - not rods
stereoplay
Deutschland
Wow&Flutter of a Dual CS628 Direct drive
stereoplay
Deutschland
I'm really impressed by this old belt driven TT, Garrard GT-20:
Please bear in mind that I use a gyroscope, so no test record can add additional W&F.
1% too fast, but really low W&F. Most of the 0.55Hz component is filtered out in the weighting filter (-10dB):
JP
Brookfield, CT
That 0.55Hz component is pretty significant, and appears to be ramping.
stereoplay
Deutschland
Yes, that is true. The 0.55Hz component is fluctuating from time to time. I made some measurements, but the readings are always similar.
MattHooper
I don't have an easy way to measure mine, but frankly I'm going with the ignorance-is-bliss approach :)
JP
Brookfield, CT
This from a DD motor FG. This is two revolutions that almost perfectly sit atop each other.
Ha-Ha
Hello,
I found this forum and discussion while searching for a detailed technical manual on the Technichs SL1200mk7. I just want to add to the fun with some recent measurements on the speed stability of a SL1200mk7. Speed is measured by counting periods between optical pulses reflected from the strobe dots along the platter rim. Measurements are made using a time-interval counter in continuous (back-to-back) sampling mode with a sampling time corresponding to two periods of the strobe dot pattern. The first figure shows the angular variation of individual frequency samples, with a total of 57 revolutions overlaid. The highly reproducible pattern suggests that the measured variations are due to geometric variations of the strobe dot pattern, and not an actual variation in the platter's rotational speed. I guess this could be investigated using a high quality test record.
Since frequency measurements are continuous and synchroneous with the actual rotation of the platter, it is easy to compute a synchroneous low pass filtered rotation speed by computing the moving average over exactly one full rotation. Such averages shown below as a deviation from the nominal rotation speed of 33 1/3 rpm.
The average speed deviation is 0.001 % and the variations around this value (averaged over one full rotation) are < 0.0015 % in magnitude. A fuller view of the data are captured in the frequency stability plot shown below.
The (modified) Allan deviation indicates the typical relative difference between consecutive values of the average frequency/speed, for a given averaging interval (tau). The first 'dip' of the stability corresponds to an averaging interval of one full rotation and simply reflects what is shown in the first figure, namely that the variations in measured speed are very reproducible from one rotation to the next. For averages over more than 5 rotations (9s), the differences are less than one part per million. The data presented here do not shown any detectable speed drift at a level 10^-7.
All in all, the SL1200mk7 has excellent speed accuracy and stability. The method used to measure the speed of rotation is likely influenced by geometrical imperfections of the strobe dot pattern and is therefore not a reliable indicator of short term speed variations (flutter). The measurements nevertheless suggest an absolute upper bound of 0.2 % of short term speed variations. For measuring short term variations, it would be better to directly access the speed sensing circuitry of the SL1200mk7 and the phase deviation values of the internal quartz lock loop. Any pointers to a service/repair manual?
Added: The strobe dot pattern along the platter rim is designed for a visual indication of speed accuracy. Circular dots makes the measurement setup sensitive to slight eccentricities. It would have been better with square shaped strobe dots. The optics of the measurment setup will likely be tweaked to get reduced sample-to-sample variations.
Ha-Ha
I found a service manual for the SL1200mk7. It seems one should be able to measure speed related signals directly from pins 1-3 on the main PCB. Speed is apparently measured using some kind of Hall sensor. The manual does not really give any details on what the different pulse signals are.
Balle Clorin
Balle Clorin
Another test record
The same test record with perfect Azimuth, thanks to @stereoplay
DSJR
Suffolk Coastal, UK
Yes, Dynavector uses a very short 1.7mm diamond rod:
I have a good new MMC20CL with fancy tip on a sapphire cantilever and can tell you this about these designs going back to the early 70's SP15 model. They're VERY temperature sensitive and sound dull and dreary if the temp is below 72 degrees or so. There was a selling point with the Beogram 4000 which came with the SP15 and when connected to the mains, the temp under the closed lid was slightly higher deliberately - this via B&O back in the 70's and not made up! In some ways, I prefer the less well measuring and more 'raw' tones of the lower model MMC20-EN
My MMC 20CL is smooth toned, low surface noise but bland for rock music (mine is in the later black coloured half inch adaptor). HiFi Choice measured it at around 70 degrees F and the hf wasn't a straight line, but having a gentle 2dB 'MM' response recess in the upper kHz region and a recovery to +1dB by 20kHz, so maybe a slower pen plot, a different test disc to B&O's or a cooler temperature...
Mind you, the ancient but funky toned Denon DL103 MC antique measures well at the beginning of side, yet loses 3dB at hf by side end due to the conical tip. None of the fans seem to notice this, but then, they haven't done comparisons with a good CD transfer at beginning or end of side, let alone measured it as many tech reviewers have.
Ha-Ha
Just for fun, here is the speed deviation for full rotations of the platter of a Technics SL1200MK7. This is based on the same data presented above, but shows the speed deviation for a time series of complete rotations, resolved for every 2nd dot of the platter strobe pattern. A total of 56 rotations are shown. Time-intervals (periods) for full rotations are calculated by taking difference of time-interval-counter timestamps for all pairs of samples spaced 91 samples apart.
Balle Clorin
Balle Clorin
Thanks for the instructions. I have just one question which I don't manage to fix and that is to "change calibration file". Should I import it as .txt in the frequency response option? I don't see where you change calibration file unless you do a measurement in the preference menu.
Sorry I did not see this,
REW has a set of tabs to the left after importing a wav file or any measurement , on the tab you can click to “change calibration”
Thomas_A
Sweden
Thanks, I found that out after some time.
