morillon
- Joined
- Apr 19, 2022
- Messages
- 1,391
- Likes
- 281
33rruert2
(2sigma?)
a recent revision of rpm and wow on android seems to have gained in rigor on this point, but especially if you have the assurance via a test like strobe 300hz (a good strobe remains a simple and effective solution), allows you to manually compensate for the observed deviation..
simple
(if the motor is not speed controlled you really have to check the mains frequency precisely... for example in my country it is normalized at +-0.1%... it is sensitive...)
(a paid software under ios seems after a sufficient qualibration test to be efficient even on the absolute speed)...
the perception of the wow flutter depends a lot on the type of music and instruments listened to etc
.it can bring a lot of perfect misunderstanding in the discussions
ok.. ;-)The phone app has an error deviation, 33.4 gives stationary strobe lines (33.336 with stylus in groove. Cannot hear any wow in music , but can on test record tone, depends on record centering also of course
(2sigma?)
simple
