Great, I am sure the LYD will be very flat in FR, and personally I am always a fan of the Adam's ribbon tweeter (hence my target for T5Vs), really wanna see how they compares
I actually had REW charts handy for the Adams... this clearly illustrates the one weakness of the design. No waveguide + ribbon tweeter = very, very small sweet spot.
What you see here is about a 5 degree difference in toe from the blue line to the red one. The T series has the same waveguide they use on the S2V so no doubt they are much better in this regard. I did more tweaks after this and got them to be a bit flatter, but it's still not great. At this point I'd actually recommend the T monitors over the As. The A design is just too old.
Looking forward to your impressions and measurements! I never listened to Dynaudio, but wonder how they compare to Genelecs
When you look at the technology involved, the Genelecs seem like a clear winner, but I wasn't super stoked on the low end response of any of the current 5" monitors out there. I think my existing monitors are as good or better, especially when compared to the Neumanns.
So I started looking at 7" monitors, and the Genelec 8040 is a revision out of date compared to the 8030. I didn't think it sounded very good - it had only a tiny bit more low end extension, a sixth of an octave (if that) and the bass was "slow" sounding. Assuming the group delay for the 8040 is the same as the published figures for the 8340, there's over 20ms of delay at 50hz. It doesn't work for the genres of music I enjoy and mix the most.
But, if I don't get on with the LYD 7s, I'll try the 8030s next. I have a separate demo for APS Klasik 2020s later this month as well.
