Genelec 8330A Review (Studio Monitor)
This is a review and detailed measurements of the Genelec 8330A studio monitor (powered speaker). It was kindly purchased by a member and drop shipped to me. The 8330A costs US $895 each.
The 8330a naturally follows the current design style of Genelec 2-way non-coaxial speakers:
This is part of the smart speakers from Genelec so naturally sports Ethernet connectivity:
I performed a factory reset before testing. I was surprised how sensitive the input was. I had to really dial down the output on my Klippel analyzer to measure it. I expect devices targeting professional market to have less gain by default when using XLR connections.
Measurements that you are about to see were performed using the Klippel Near-field Scanner (NFS). This is a robotic measurement system that analyzes the speaker all around and is able (using advanced mathematics and dual scan) to subtract room reflections (so where I measure it doesn't matter). It also measures the speaker at close distance ("near-field") which sharply reduces the impact of room noise. Using computational acoustics, far-field response is computed and that is what I present. Both of these factors enable testing in ordinary rooms yet results that can be more accurate than an anechoic chamber.
I performed over 1000 measurement which resulted in error rate of about 1%. Clean high frequency response is responsible for ease of measurement in this regard.
Reference axis is approximately the outer rim of the woofer as instructed in the manual.
Genelec 8330A Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
I am so used to nearly ruler flat on-axis response from Genelec that the little bit of variation around crossover region stands out. As does some directivity error. Here is the near-field response:
Can't figure out why the woofer response is sloping down and then rising. That is responsible for on-axis response going above flat response.
Early window reflections are less smooth than I expect from Genelec:
Genelec 8330a Early Window Frequency Response Meaurements Powered Studio Monitor.png
Fortunately it all averages out quite well for far field listening:
Genelec 8330a Predicted In-room Frequency Response Meaurements Powered Studio Monitor.png
I was surprised to see the clipping light (amber and red) come on during the bass region of 96 dBSPL sweeps. Measurements show that the speaker is outside of its comfort at that level:
Genelec 8330a distortion vs Frequency Response Meaurements Powered Studio Monitor.png
Genelec 8330a relative distortion vs Frequency Response Meaurements Powered Studio Monitor.png
Ignoring the bit of directivity error around crossover, the rest of the response horizontally is good:
Genelec 8330a horizontal directivty width Meaurements Powered Studio Monitor.png
Vertically response is above average with good bit of leeway above and below tweeter axis before you get into trouble:
We see the directivity error at 3 kHz visualized better in our 3-D contour map:
Notice how the pattern has become quite directional and complex.
Finally, here are the timing graphs for the fans of such:
We see some clear resonances around 2 kHz center frequency.
Genelec 8330A Listening Tests
It doesn't take but a minute of listening to know that a) the tonality is right and b) matches other Genelec speakers. I attempted to EQ out the resonances around 2 kHz but it was hard to decide whether that was always an improvement or not. Taking that out makes the speaker sound a bit warmer but also more closed in. It is subtle though.
Dynamic range even in near field listening that I was using is not great. It is easy to get the red clipping light to come on during playback of anything with bass notes. Mind you, it is reasonably loud before that but it just isn't enough.
By most other speakers, the Genelec 8330A speakers have excellent measurements. But using a much higher standard, I feel that they are not as well matched and executed as the 8320A which I reviewed before. The larger woofer has resulted in less perfect crossover response. And there is not enough amplification here to do the speaker justice.
Still, if you don't exceed its playback limits, you have a wonderful sounding speaker here. Tonality is almost as good as it gets. It is not only correct but very enjoyable.
I am going to recommend the Genelec 8330A.
  • Genelec 8330a frequency response.zip
dfuller
This has been the case with every active monitor I've ever owned, they all have super hot inputs. The KH310s and the Footprint01s were the only ones that haven't been way, way too hot.
Hmm... This is interesting. I wonder why this one is more sloped down than most monitors. Doesn't seem to quite be in line with the rest of Genelec's offerings.
They usually have a switch though or a knob. With neither here, I am surprised the default is consumer levels.
sam_adams
Genelecs always seem to perform very well. They have a smooth, controlled bass rolloff that allows them to integrate well with a sub—especially if you're using GLM. These probably wouldn't dissapoint in the least in a studio setting with all the bells and whistles added.
Sancus
The slope isn't really that different from the 8030C is it? Both slope from 86dB at 100hz down to 81dB at 10khz. Perhaps the 8330A is like 0.25dB lower by that point, hard to tell, but looks pretty similar to me. Other than the 1-2khz region, it's flatter in general, which one would expect from a DSP-corrected monitor.
Kind of weird that the 8030C has a dip from 2-3khz and the 8330A has a peak in almost the same region. Overcorrection?
Sancus
They set all their monitors to the same for consistency. The 8320A/8330A lack the analog pot, not sure why(physical internal space issue?), but larger ones have them. I do find it odd that they set all their monitors to highest sensitivity by default, but perhaps it reduces support requests with "why is my monitor so quiet".
You can, of course, change the sensitivity with GLM, but I'm sure you're aware of that.
MaxRockbin
Portland, Oregon
Isn't the only difference between 8330A and 8030C the SAM room correction? Amps, drivers, enclosure all the same?
So it's strange that these have that 1-3K bump. And I don't remember a mention of the clipping light coming on for the 96dB distortion sweep with the 8030c.
Sancus
On the 8330A the crossover is implemented digitally and so is the built-in correction.
phoenixdogfan
Nashville
Would be interesting to see how they would do with GLM. Sub would help, but would their electronics limit output regardless?
wwenze
The impulse response looks nice.
Maybe one day somebody will do an experiment of "Are impulse responses audible?"
Sancus
So weird that these measure worse than the 8030c.
Do they, though? The on-axis appears worse, however, these were measured with the higher number of points so one would expect it to be worse. The 8330A's PIR though ends up marginally better, perhaps. The slight broad dip from 100-500hz is better corrected, so is the sharp drop above 15khz, and the broad crossover dip is instead a dip and then peak. It's possible that this is intentional and ends up sounding better than the broad dip, I don't know.
In any case even looking at Genelec's own measurements and specs I don't think they were ever a sound upgrade, it's purely for GLM. Unlike some other 8000-series, the 8030C already has the newer Class D architecture.
YSC
I personally would expect with DSP inside the default tuning was calibrated more to be anechoically flat though
buxtehude
New York, NY
For my apartment living room with no treatment, 8330 with GLM correction made a huge difference. I am not versed in this area so please forgive me but without the correction, there was some kind of unpleasant ringing in the lower mid-area. Making the sound muddy. After the correction, all the ringing is gone. Crystal clear to my ear. I know the GLM kit was not cheap but 8330 & GLM combo was worth every penny :)
Maiky76
French, living in China
Hi,
Here is my take on the EQ.
These EQ are anechoic EQ to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 5.6
With Sub: 7.9
Spinorama with no EQ:
  • 1-3k range not very smooth?
  • A directivity error at the XO point
  • Port seems OK
  • LF run out os steam so I added a HP.
Directivity:
Better stay at tweeter height
Horizontally, up to 20deg
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 5.8
with sub: 8.0
Score EQ Score: 6.1
with sub: 8.3
Code:
Genelec 8330a APO EQ LW 96000Hz
August122021-121119
Preamp: -1.9 dB
Filter 1: ON HPQ Fc 45.10,    0.00,    1.15
Filter 2: ON PK Fc 104.00,    -1.50,    1.90
Filter 3: ON PK Fc 552.00,    -1.50,    2.00
Filter 4: ON PK Fc 1933.00,    -2.30,    2.87
Filter 5: ON PK Fc 4270.00,    -0.50,    0.82
Filter 6: ON PK Fc 14377.00,    0.80,    0.70
Genelec 8330a APO EQ Score 96000Hz
August122021-121006
Preamp: -0.4 dB
Filter 1: ON HPQ Fc 43.59,    0.00,    0.97
Filter 2: ON PK Fc 88.88,    -1.69,    1.39
Filter 3: ON PK Fc 504.32,    -1.50,    1.45
Filter 4: ON PK Fc 1879.81,    -2.90,    2.73
Filter 5: ON PK Fc 5296.75,    -0.68,    0.62
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Tiny improvements
The rest of the plots is attached.
  • Genelec 8330a APO EQ LW 96000Hz.txt
  • Genelec 8330a APO EQ Score 96000Hz.txt
soundwave76
Finland
So weird that these measure worse than the 8030c. Thanks for the review. Was thinking of upgrading my 8030s to 8330s, so saved me some money.
Absolutelly upgrade. The 8330 are superior to the 8030 because of the GLM room correction. If you apply room correction with some other means, then that’s a different case. I upgraded my 8030 first to 8330 and the improvement was huge, thanks to room correction. Later I upgraded to 8331 and there was improvement yes, but not nearly as much as with the first upgrade.
