dc655321
- Joined
- Mar 4, 2018
- Messages
- 1,597
- Likes
- 2,236
I think it was part of my algebra in Maths class decades ago, so I can't remember it.
I had a thought though re the interpretation of the graph, and correct me if you know I'm wrong, assuming you understand it:
Is the Harmonic Distortion occuring at minus numbers on the X-axis there because the microphone is capturing the Harmonic Distortion, which is obviously at a higher frequency than the initial excitation frequency that caused that harmonic distortion, and therefore the microphone is capturing a reading at that higher frequency that hasn't been yet played in the chirp - if that's the case then I can understand why the harmonic distortions are listed in that graph in ever decreasing minus values on the x-axis because as you go up the different harmonic distortions from 2nd through 3rd through 4th (etc) then the microphone is picking up a response at those higher frequencies that have yet to be played during the chirp. So the minus time relevance is how much earlier the microphone picks up a significant reading for a given frequency earlier than expected in comparison to the fundamental chirp, and therefore that's how it recognises harmonic distortion from the fundamental chirp.
"Complex Numbers" red-herring aside, I think you've kinda got it!
Obviously the HD signal is simultaneous with the excitation signal, so the delays are calculation/model artifacts.
Personally, I find it clearer to reason about the above in the frequency domain view (Fig 5 below, from the paper @NTK linked), where the time and frequency relationships are more obvious.
Maybe it would've helped to clarify in the time-domain image that "2nd Harmonic" is 2nd harmonic distortion across all frequencies? YMMV of course.
