HTD Level THREE Review (Bookshelf Speaker)
pavuol
EU next to warzone :.(
HTD Level 3 Listening Tests
The immediate reaction was the extreme shrillness of the highs. It is over the top unless you have lost all of your high frequency hearing in which case, it sounds fine. :)
At times, I enjoyed listening to them despite all the flaws there. This may be due to controlled horizontal directivity.
YSC
Holy... this is real bad... (looking at flee market dice size speakers bought for mum 20 years ago) now those flee market sound emitting devices don't seems like that bad, at least it's only $10
thewas
Hi,
Here is my take on the EQ.
These EQ are anechoic EQ to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 0.1
With Sub: 2.2
Note: the Canon and speakers have low scores indeed but the model is probably not adequate to score them because of their directivity
Spinorama with no EQ:
  • Resonances!!
  • Too many better speakers to end up with this one
Directivity:
1kHz mess!
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 2.5
with sub: 4.6
Score EQ Score: 3.1
with sub: 5.2
Code:
HTD Level 3 APO EQ LW 96000Hz
September132021-110743
Preamp: -2.2 dB
Filter 1: ON HPQ Fc 30.94,    0.00,    0.55
Filter 2: ON PK Fc 268.73,    -1.39,    5.98
Filter 3: ON PK Fc 354.73,    -3.39,    5.98
Filter 4: ON PK Fc 412.01,    2.99,    3.70
Filter 5: ON PK Fc 702.43,    -4.26,    5.76
Filter 6: ON PK Fc 967.52,    2.85,    2.06
Filter 7: ON PK Fc 2232.74,    -1.04,    0.69
Filter 8: ON PK Fc 7391.51,    -2.00,    4.71
Filter 9: ON PK Fc 9472.64,    -3.47,    5.13
Filter 10: ON PK Fc 15125.03,    -8.98,    1.22
HTD Level 3 APO EQ Score 96000Hz
September132021-110652
Preamp: -2 dB
Filter 1: ON HPQ Fc 34.91,    0.00,    0.70
Filter 2: ON PK Fc 281.82,    -0.98,    5.98
Filter 3: ON PK Fc 354.64,    -3.39,    5.98
Filter 4: ON PK Fc 397.23,    2.99,    4.90
Filter 5: ON PK Fc 700.43,    -4.26,    5.76
Filter 6: ON PK Fc 915.87,    2.85,    1.81
Filter 7: ON PK Fc 2281.26,    -1.53,    0.69
Filter 8: ON PK Fc 7223.31,    -3.00,    5.95
Filter 9: ON PK Fc 9555.98,    -4.98,    5.80
Filter 10: ON PK Fc 14501.36,    -9.70,    1.22
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Large improvements but still KO...
The rest of the plots is attached.
Nice to see how the Harman score correctly still heavily punishes them after EQ and despite their decent horizontal directivity due to their multiple resonances.
HorizonsEdge
I am quite distraught (hyperbole)
I bought the Level 2 version of these 3 years ago (L/R/C) after many strong recommendations. I have been mostly satisfied with these in a HT configuration. Music not so much. It was my first foray into audio of any kind. Just goes to show you that you just don't know what you don't know.
vkvedam
Coventry, UK
The only word that comes to my mind is "wow" as is "wow, that is bad!" There are so many problems here. First and foremost is the peaking tweeter response as frequencies climb. The overall response is so jagged and we have some sudden anomalies. Sensitivity is also quite low as evidenced by me having to turn up the gain to measure the speaker by some 4 to 5 dB above average speaker. For some clues as to why the response is so bad, I disconnected the rear binding posts from upper and lower halves and measured the tweeter and woofer independently:
Those peaking highs remind me of the NYC Skyline when I first visited the city :p
Koeitje
A preference score of just .2, wow a new high in lows. A headless panther isn't enough for this. Let's get one that was run over by an F-150. thank you @amirm for knocking another fairy tale into the weeds.
Didn't we already see a speaker get a negative preference score?
tecnogadget
Madrid, Spain
I’ve come to the conclusion many inexperienced Home Theater newbies like that high rise slope, it makes all those Cymbals/Violins/Trumpet/Clarinet from soundtracks very distinctive.
Interesting theory. We should test a few more darlings of home theater budget crowd to see if the characteristic is common to all.
Thomas_A
Sweden
We need more Panthers with heads now! :cool: These headless ones makes me sad.
Rottmannash
Nashville
This is a review and detailed measurements of the HTD Level 3 bookshelf speaker. I got talked into buying it by members due to its popularity in home theater forum. For you all's sake, it better perform! :D I don't remember what it cost me but the current price in black is US $429 from the company direct.
I must say, I am very pleased with the way they look:
I guess I have a soft spot for white woofers. I also like the rather serious look of that tweeter.
Back panel shows a couple of screws which should make it much easier to hang this from walls for your side and rear channels:
Screw binding posts are too close together making it a pain to tighten or loosen them.
Measurements that you are about to see were performed using the Klippel Near-field Scanner (NFS). This is a robotic measurement system that analyzes the speaker all around and is able (using advanced mathematics and dual scan) to subtract room reflections (so where I measure it doesn't matter). It also measures the speaker at close distance ("near-field") which sharply reduces the impact of room noise. Using computational acoustics, far-field response is computed and that is what I present. Both of these factors enable testing in ordinary rooms yet results that can be more accurate than an anechoic chamber.
I performed over 1000 measurement which resulted in error rate of about 1%. Clean high frequency response is responsible for ease of measurement in this regard.
Reference axis is approximately the center of the tweeter. Grill was not used.
HTD Level Three Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
We clearly see some of the issues behind our frequency response errors. The port is letting out some nasty resonances and the tweeter response is anything but smooth and flat.
Even the impedance measurement shows us something seriously is wrong:
One can say that getting proper frequency response is difficult for smaller companies but impedance measurements are dead simple. Whatever is going on around 260 Hz should have been found and dealt with. While on this graph, unlike many speakers, the minimum impedance is ht around 2 khz to the tune of 3.6 ohm. For bass frequencies it is above 6 ohm which is good.
Back to our "spin" information, let's look at the early and strongest reflections in a typical room:
We see many of the same problems here. As noted, if you put an absorber behind your seating position (your back wall, speaker's "front wall"), it may help with the extra brightness.
Predicted in-room response smooths out some of the problems but leaves a lot:
There is some good news in the form of very good directivity control of the tweeter in the horizontal dimension:
Vertically is a mess but so are many 2-way speakers:
Getting proper distortion measurements is hard because the frequency response is so wild. I adjusted it for mid-range levels and got these:
These are some of the worst distortion measurements on record but note that many of the issues are narrow peaks so audibility will not be as bad it may look.
The immediate reaction was the extreme shrillness of the highs. It is over the top unless you have lost all of your high frequency hearing in which case, it sounds fine. :) This "showroom sound" can sound appealing -- for a bit at least -- so please don't write that you don't think it sounds bright. Measurements say so as do my ears. But the overall feeling of clarity that such overboosted highs present is hard to deny.
There is some cleverness in the bass response in that this speaker can play very loud without bottoming out. It simply filters out deep bass that it can't play so fits its intended usage of home theater sound with subs and such.
I did not bother to develop an EQ. There are just too many issues here to deal with. Best to get a better speaker that doesn't require so many fixes.
Objectively the HTD Level 3 is a disaster. Clearly no measurements were performed to verify efficacy of the design. That said, while some aspects like high frequency boost are clearly audible and annoying, the rest of the response hurt the eye more than the ear. Bass tuning is clever to keep the speaker from distorting and hence allowing it to play quite loud. And there is something to that wide and controlled horizontal directivity that I can't quantify but I think contributed to sound that is not nearly as bad as measurements show.
We could look at this speaker as a puzzle given the huge number of flaws in its design but yet, not so horrible sound and try to figure out what is going on. Me? I just rather get a good speaker that doesn't make me spend this kind of effort on it. :) The designer should do more than is delivered here so my work is touch up and no more.
I can't recommend the HTD Level Three and curse all of you who made me buy it. :)
Thanks for the review. What do you do with equipment you buy to review? Sell it? Give it away? Burn it?
Dmitri
One trick I’ve found helpful to understanding concepts that I find difficult to comprehend is to look at them at their extremes.
So yeah. WOW. I get it now.
Thanks Amirm!
Mauro
Why not reviewing Wharfedale competent and cheap speakers instead of this :facepalm::facepalm::facepalm:?
More people would be better served..
tomtoo
Germany
I wonder whats the thinking behind.
Provokative i say, i could build a speaker only with catalog data and schoolbook x-overs that has less FR deviation. So why they do this?
